I’ve dug up and old BeagleBone Black A6 that has Angstrom on the eMMC. It won’t boot off an SD with a current image (** Invalid partition 2 **).
How do I update it to run a current image?
–Mark
–Mark
Hold the "boot" button, insert power.
I’ve tried that and it doesn’t work. Here’s what I get:
U-Boot SPL 2013.04-dirty (Jul 10 2013 - 14:02:53)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
** File not found uEnv.txt **
It's still reading from the eMMC first. .
Sometimes my thumb doesn't work right, then i just short the pin
connected to the push button to GND
Well that was the problem, it’s now happily reflashing the eMMC.
Thanks for the help…
–Mark
