Updating to the most recent of R Nelson's kernel sources
Does anyone know the set of git commands needed to update one of R Nelson’s kernel sources? His original shell scripts are faultless, but the only way I can find to update a build to the most recent version is to wipe the directory and start again with a full download. This needs several hours and a fast connection, and there must be some set of git fetch commands that would just get the most recent files needed. However, git and I are violently antipathetic, and I can’t find out what those commands might be.
Thanks for any ideas - Will
Did you try a simple:
  git pull origin
...from inside your working copy?
Also, take a look at the system.sh.sample file. If you have a Linux
kernel git repository locally (or care to create one), you can point to
it with a system.sh file (created using the system.sh.sample as an
example) and it will get reused so you won't need to download it each
time you build. Robert's scripts will download and reuse a copy of the
kernel source for you, but it's inside the working directory so if you
delete everything and re-clone the Robert's linux-dev repo, you'll have
to download the kernel source all over again.
git checkout master -f
git pull
