I managed to create an working copy of the initial SD-card image
on a 16GB SD card.
This card boots fine.
As adviced I did a
opkg update
opkg upgrade
. Unfortunately there were many lines containing "no space left on
device" and "wget .... short write" messages.
The both lines, which are often repeated in the logs are:
/usr/share/opkg/intercept/depmod: line 4: echo: write error: No space left on device
Configuring kernel-module-emc2103.
Configuring kernel-module-ah6.
Configuring kernel-module-ah4.
Configuring kernel-module-ssu100.
Configuring kernel-module-esd-usb2.
Configuring kernel-module-usbled.
Configuring kernel-module-ad7192.
Configuring kernel-module-ad7746.
Configuring kernel-module-ltc4261.
Configuring kernel-module-saa7115.
Configuring kernel-module-rc-dntv-live-dvbt-pro.
Configuring kernel-module-videobuf2-memops.
and
Upgrading kernel-module-tea5761 on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-tea5761_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
Upgrading kernel-module-sch-hfsc on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-sch-hfsc_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
Upgrading gst-plugins-base-videotestsrc on root from 0.10.36-r3 to 0.10.36-r6...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/gstreamer/gst-plugins-base-videotestsrc_0.10.36-r6_armv7a.ipk.
wget: short write
Upgrading kernel-module-mt2266 on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-mt2266_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
Upgrading kernel-module-xfs on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-xfs_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
Upgrading kernel-module-ppp-deflate on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-ppp-deflate_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
Upgrading kernel-module-tea5767 on root from 3.2.18-r12j+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 to 3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01...
Downloading http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv7a/machine/beaglebone/kernel-module-tea5767_3.2.25-r15a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01_beaglebone.ipk.
wget: short write
This also happened before with the 4GB image (which I reinitialized
with dd of the backupped original image in beforehand of the upgrade
procedure of the 16GB SD card).
Is it really true that I need more than a 16GB SD card to upgrade an
image which is delivered on a 4GB card?
What does all the errors mean?
Thank you very much in advance for any help!
Best regards,
mcc
PS: Log file is available and can be mailed too, if wanted.
