upgrade fails
Hi
I am running angstrom from an image built by Narcissus in january
(kernel 2.6.27). It's a CLI only system.
Upgrading does not work: "opkg upgrade" gets stuck at coreutils. "opkg
upgrade coreutils" alone gets stuck as well. I manually downloaded
coreutils and ran "opkg install coreutils.ipk" (forgot the full name)
and it still does not work.
By stuck I mean that the system freezes. I need to power off and on
again.
what can I do?
Brice
Hi
again.
what can I do?
It's a bug in opkg, which should be solved when we update opkg to a newer revision tomorrow.
regards,
Koen
Just a heads up - same happens with busybox upgrade 1.11 -> 1.13
