Upgrades
Angstrom-Beagleboard-demo-image-glibc-ipk-2009.X-stable-20090612--beagleboard.rootfs.tar.bz
contains a 2.6.29-r37 kernel, but "opkg upgrade" installed a
2.6.29-r35+git one instead.
I've seen unstable has a 2.6.29-r41 kernel, but no distribution built
for it.
Other than installing individual packages, is there a way to upgrade to
unstable?
Perhaps by altering the URL's in /etc/opkg/* to point to unstable?
Thanks and Regards
Sid.
Still trying. I am using wget to download the unstable packages, then I
shall try upgrading from the local directory.
Regards
Sid.
switching to unstable is only supported by a reinstall, too many
things have changed.
Op 15 aug 2009 om 03:29 heeft Sid Boyce <sboyce@blueyonder.co.uk> het
volgende geschreven:\
Presumably I can do that with opkg from a local directory. It would have
been nice if the same was done for beagleboard as for other boards,
producing a tar.bz2 file which could make it easier.
Regards
Sid.
Op 15 aug 2009 om 18:31 heeft Sid Boyce <sboyce@blueyonder.co.uk> het
have
you mean like Narcissus does for you?
have
Thanks, never heard of it before, used google to find it and the built
image is now downloading - very neat.
Regards
Sid.
