avi
March 15, 2010, 1:07pm
1
Hi All,
This is my first Bit bake on OE.
Is this expected?? BitBake consuming more than 25 GB of hard Disk!!
Please suggest me if I need to Kill the process as I will be running
out of memory soon
I am following the guide :
http://wiki.openembedded.org/index.php/Getting_Started
I am trying to do my first BitBake with the command
$ bitbake x11-image
The command is running for past 7 hours and completed only 1666 task
of 4786.
I have about 30 GB HD partition for Ubuntu 9.10 .
I observed :
/home/avinash/oe/build/tmp/ is consuming all the space
/home/avinash/oe/build/tmp/work is occupying about 12 GB space
Also If there is nothing wrong with Bitbake , Please let me know what
is the memory requierement for building Angstrom?
Will using external hard Disk for BitBake have any issues?? like
symlink or any thing?
Thanks & Regards
Avinash
Hi All,
out of memory soon
$ bitbake x11-image
of 4786.
I observed :
External harddrive should be OK. Do not use a symlink above the OE
directory. Autoconf (or something related) has trouble with that and
your build will fail.
Adding:
INHERIT += "rm_work"
will also help. At the expense of deleting the build results for all packages.
Philip
avi
March 15, 2010, 1:38pm
3
Thanks Philip!!
But can you guess what is the usual space take by bitbake. so that i
could be better prepared for my next build.
Shall I assume there is no Issue with this Bitbake which is running
for hours
and consumed major chunk of my hard disk.abt 20 GB now.
Unfortunately I might have to kill this process and rerun on external
drive.
Thanks Again!!
Avinash
Thanks Philip!!
For me It's only 8.3 GB,With INHERIT += "rm_work"
for hours
Yes I think there is no issue with your bitbake , Also It's depend on
your internet speed.
avi
March 15, 2010, 1:55pm
5
Thanks Sunny ,
Just a Wild Guess, could I delete some files manually so as to free
some space!! like what rm_work is supposed to do.
It could save me a lot of time .
If yes, please suggest me which folder I could delete?
is it /home/avinash/oe/build/tmp/work. - its taken abt 10 GB space
Internet speed is pretty good at abt 100 K/s
Dear avi,
You can look for the `download` directory. I do not know if `rm_work`
also deletes the archives.
Paul
What’s the point to delete “download” directory??? To download all those hundreds packages again?? You better delete OE/build/tmp directory
2010/3/15 Paul Menzel <pm.debian@googlemail.com >
