USB camera flicker issue
I had connected a USB camera to the beagle XM board running Linux 3.4.7-x1 and it worked successfully( tested with camorama application).
As I was facing issues with USB mounted on the beagleboard at low temperatures, I applied the patch https://github.com/RobertCNelson/stable-kernel/blob/v3.4.x/patches/omap_fixes/0001-Fix-sprz319-erratum-2.1.patch
After applying the patch, the board works fine at low temperatures but the USB camera output flickers using the camorama application.
Camera details(lsusb output)
Bus 001 Device 005: ID 058f:5608 Alcor Micro Corp.
Dmesg output for video
dmesg | grep video
[ 8.462341] Linux video capture interface: v2.00
[ 8.616485] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (058f:5608)
[ 8.680419] usbcore: registered new interface driver uvcvideo
Any pointers will be appreciated.
Valareyano
stable-kernel/patches/omap_fixes/0001-Fix-sprz319-erratum-2.1.patch at v3.4.x · RobertCNelson/stable-kernel · GitHub
"low temperatures" aka lower then what the board is spec'd for? I'm
not supporting that.
dmesg | grep video
Grab the latest, lots of usb fixes, 3.4.x is ancient..
http://elinux.org/BeagleBoardDebian#BeagleBoard_xM
