Is anyone having trouble with random USB disconnects when letting the board
run all the time?
Or is it just my kernel or board or usb hub or devices?
It happens every few hours, but I've been unable to time it exactly.... I'm
starting a log on the terminal now.
Kevin
musb_stage2_irq 803: unhandled DISCONNECT transition (a_wait_bcon)
usb 2-1: USB disconnect, address 54
usb 2-1.1: USB disconnect, address 55
usb 2-1.1.3: USB disconnect, address 56
usb 2-1.1.4: USB disconnect, address 57
wlan0: unregister 'rndis_wlan' usb-musb_hdrc.0-1.1.4, Wireless RNDIS device,
BCM4320b based
usb 2-1: new high speed USB device using musb_hdrc and address 58
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
usb 2-1.1: new high speed USB device using musb_hdrc and address 59
usb 2-1.1: configuration #1 chosen from 1 choice
hub 2-1.1:1.0: USB hub found
hub 2-1.1:1.0: 4 ports detected
usb 2-1.1.3: new low speed USB device using musb_hdrc and address 60
usb 2-1.1.3: device v413c p2105 is not supported
usb 2-1.1.3: configuration #1 chosen from 1 choice
input: Dell Dell USB Keyboard as /class/input/input15
input: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on
usb-musb_hdrc.0-1.1.3
usb 2-1.1.4: new high speed USB device using musb_hdrc and address 61
usb 2-1.1.4: device v13b1 p0014 is not supported
usb 2-1.1.4: configuration #1 chosen from 1 choice
rndis_wlan 2-1.1.4:1.0: rndis media disconnect
wlan0: register 'rndis_wlan' at usb-musb_hdrc.0-1.1.4, Wireless RNDIS
device, BCM4320b based, 00:12:17:6a:a9:74
rndis_wlan 2-1.1.4:1.0: rndis media connect
Kevin
