USB drive settings file
I would like to know what file controls the USB drive that Beaglebone Black provides when connected to a PC via USB.
I tried to find some of the files/names from the drive within the Debian image file and on the beaglebone but no luck identifying what directories are used. I did find where the IP’s are being set for the USB connection but nothing about the mnt points when a USB connection is made.
Is the USB drive area a physical partition? When opening the image file I would of assumed this would be visible there - so I don’t think this is the case.
I’m stumped - appreciate anyone’s input here.
It's a raw *.img file, if you want to use a difference image or a raw partition:
look at the "usb_image_file" variable in:
/opt/scripts/boot/am335x_evm.sh
Thank you!
