Hi all,
I tried a Debian install on the BeagleBoard (from http://rcn-ee.net/deb/kernel/…).
My idea was to make RAID available by mdadm (software raid), plug two
disks and get a cheap homeserver. For this, I had to install a module-
enabled kernel and install mdadm. That's where things get cloudy…
Every USB device I stress, by a dd or a RAID sync gets this "warning"
in syslog: "reset high speed USB…"; then it can disappear from the
system randomly.
The workaround for this is to boot with "irqpoll". But the drawback
now is that I can't get any better than 2MB/s write speed!
Unfortunately, I found no hints about this specific problem...
Thanks in advance!
Any chance you can let us know what revision of board you have?
Hi all,
enabled kernel and install mdadm. That's where things get cloudy...
in syslog: "reset high speed USB..."; then it can disappear from the
system randomly.
This could be a couple things... For reference, is it a Bx, C2/3 or a
C4 board and ehci or otg port and which kernel are you using from my
hosting site? 'uname -a'
I can't access my home network at the moment, thinking lighting took
out my ups as i'm traveling, but my beagles usually got 20-30MB/s thru
hdparm -tT..
