USB-ethernet Beagleboard
HI I want to know which are the boot args for a beagle board in order
to boot with the USB-ethernet adapter
I have already enable the usb-ethernet adapter on my kernel image
when i plug my usb-ethernet converter
usb 1-2.4: new high speed USB device using ehci-omap and address 6
eth0: register 'asix' at usb-ehci-omap.0-2.4, ASIX AX88772 USB 2.0
Ethernet, 00:00:00:00:30:10
if I run
# busybox ifconfig
lo Link encap:Local Loopback
          inet addr:127.0.0.1 Mask:255.0.0.0
          UP LOOPBACK RUNNING MTU:16436 Metric:1
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
and then in order to enable the ethernet
ifconfig eth0 up
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
# eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ifconfig eth0 "the ip addrs"
# busybox ifconfig
eth0 Link encap:Ethernet HWaddr 00:00:00:00:30:10
          inet addr:10.79.0.43 Bcast:10.255.255.255 Mask:255.0.0.0
          RX packets:67 errors:0 dropped:0 overruns:0 frame:0
          collisions:0 txqueuelen:1000
          RX bytes:8620 (8.4 KiB) TX bytes:0 (0.0 B)
and i can do ping to my host computer
but how can i enable the ip gateway and netmask from my boot args. ?
if i put this as boot args
setenv bootargs 'mem=128M androidboot.console=ttyS2 console=tty0
console=ttyS2,115200n8 ip=10.15.0.1::10.100.1.1:255.255.254.0:eth0
root=/dev/mmcblk0p2 rw init=/init rootwait
omapfb.video_mode=640x480MR-16@60'
the log of my kernel is
IP-Config: Complete:
     device=usb0, addr=10.79.0.43, mask=255.255.255.0, gw=10.79.0.1,
     host=eth0, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running
e2fsck is recommended
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 168K
Warning: unable to open an initial console.
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
# warning: `zygote' uses 32-bit capabilities (legacy support in use)
# busybox ifconfig
          RX packets:33 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4914 (4.7 KiB) TX bytes:2768 (2.7 KiB)
usb0 Link encap:Ethernet HWaddr 22:EA:38:38:3D:71
          inet addr:10.79.0.43 Bcast:10.79.0.255 Mask:255.255.255.0
Thanks a lot for your help
Regards
Victor Rodriguez
Try adding ":off" at the end of the ip= argument. Also, either add a
hostname before the device name or add an extra colon. So something
like this:
ip=10.15.0.1::10.100.1.1:255.255.254.0:myhost:eth0:off
Hi Victor,
Are you _sure_ you want to do this from U-Boot "bootargs" but not in "/
etc/network/interfaces"?
auto eth0
iface eth0 inet static
address 10.79.0.43
netmask 255.255.254.0
broadcast 10.79.0.255
gateway 10.79.0.1
Cheers,
Max.
Hi Victor,
auto eth0
address 10.79.0.43
gateway 10.79.0.1
Cheers,
Max.
HI Max thanks a lot but I am on android :frowning: but I will look for the
same file on android
Thanks a lot for the help
Regards
Victor Rodriguez
