USB Gadget control endpoint processing to handle vendor specific requests
I hope maybe some knowledgeable Linux USB device driver expert or
programmer can help me with this; I guess I can wish for David
Brownell's help but that's wishing too much Anyways, here's my
situation. For my project, I need to modify the g_ether driver
(specifically the driver file ether.c) to be able to handle some
"vendor specific" traffic on Control Endpoint 0 (ep0). Normally,
control endpoints only process standard USB requests
(USB_TYPE_STANDARD); for my project, I need to modify it to also
process vendor-specific USB request (USB_TYPE_VENDOR). I was able to
track the processing in (drivers/usb/gadget) down to the composite.c
module and all endpoint request goes through the composite_setup
function, which currently only support USB standard requests (such as
get USB descriptors, set USB configuration, set USB interface, etc). I
was able to modify composite.c to call a vendor callback function I
added to ether.c if the type is USB_TYPE_VENDOR.
In the vendor callback function I added to ether.c, I was able to send
the USB request data up to a userspace application via a character
driver interface. However, a "GET" request requires this vendor
callback function to "wait" for the userspace app to send the response
down to it via the character driver. It seems to work when I sent a
vendor specific USB control message from the host to the target
BeagleBoard; the Get request made it through the g_ether driver to the
vendor specific callback function and up to the userspace application.
However, this is where the driver crashes (waiting for the GET request
response data so that it can send it back to the host).
I know I'm violating all kinds of rules but please forgive me as I'm
new to Linux kernel programming. I tried searching the web for help or
driver examples on how to implement this but I can't find any. I tried
to use the libusb API but that is just for "host" programming, not
"peripheral" programming. Can someone please provide guidance, advice,
links, examples, etc on how I can properly implement this vendor
specific control endpoint processing, which will forward the vendor-
specific requests from the g_ether driver up to a userspace
application and then "waits" for the response data from it so that it
can return the data back to the host on the other end?
Andy
Brownell’s help but that’s wishing too much Anyways, here’s my
“vendor specific” traffic on Control Endpoint 0 (ep0). Normally,
driver interface. However, a “GET” request requires this vendor
callback function to “wait” for the userspace app to send the response
I know I’m violating all kinds of rules but please forgive me as I’m
driver examples on how to implement this but I can’t find any. I tried
to use the libusb API but that is just for “host” programming, not
“peripheral” programming. Can someone please provide guidance, advice,
application and then “waits” for the response data from it so that it
Andy
hi,
i m also new to linux kernel programming , in my project i m working on USB audio class gadget driver.
In case of audio class i have read in audio class specification that
" The Audio Device Class supports one additional class-specific request:
Memory Requests. Every addressable Entity in the audio function (Clock Entity, Terminal, Unit,
Interface, and Endpoint) can expose a memory-mapped interface that provides the means to
generically manipulate the Entity. Vendor-specific Control implementations could be based on this
type of request."
I think it can be a example for you to implement analogy in case of ethernet. such option may be already available in case of ethernet class also ,see ethernet class specification ,otherwise u can implement something similar to that.
Pls let me also know what u think… :slight_smile:
cheers,
Yadi.
Did you resolve this? I am trying to do something very similar.
