Hi all,
I currently try to get USB device functionality (USB-gadget) working
with beagleboard and a recent kernel (2.6.31). My plan is to emulate
a HID (mouse / keyboard) via gadgetfs.
I use OpenEmbedded / bitbake as build environment and modified the
kernel config
as described here: http://wh1t3s.com/2009/05/11/oe-bitake-kernel-mods/
I enabled all gadget-related stuff (e.g. the omap_udc, gadgetfs and
other modules)
and have them in my rootfs under /lib/modules....
however, when i try to get it running like described here:
http://svcs.cs.pdx.edu/pipermail/usb-hacking/2007-March/000098.html ,
I fail at the first steps (omap_udc.ko simply does not exist - using
menuconfig i can only
have this as a permanent module, modprobe omap_udc fails.)
the modules gadgetfs or g_ether cannot bind to the omap_udc driver.
furthermore, mount -t gadgetfs /dev/gadget does not succeed
(filesystem gadgetfs not known)
I tried a lot with the kernel-config, but obviously I'm missing
something.
could you please help out ?
regards,
chris.
