USB Host Failure
I have two bones, one with ubuntu 13 and one with factory settings. I’ve been using the ubuntu one predominantly until last night when the usb host failed. It’s very unclear to me why because everything else seems to be working (i2cdetect detects other device, gpio pins receive data, usb slave is good). I tested out the usb devices I’ve been using on both my computer and the other bone with success.
I’ve also tried both restarting the bone and the usbreset suggestion that Arthur proposed here. Neither worked.
Does anyone have any idea what this could be? Dmesg isn’t telling me much:
[ 16.587891] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 16.588291] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 16.588324] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 16.588407] usb usb2: default language 0x0409
[ 16.588444] usb usb2: udev 1, busnum 2, minor = 128
[ 16.588457] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 16.588469] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 16.588481] usb usb2: Product: MUSB HDRC host driver
[ 16.588492] usb usb2: Manufacturer: Linux 3.8.13-bone21 musb-hcd
[ 16.588502] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 16.592589] usb usb2: usb_probe_device
[ 16.592613] usb usb2: configuration #1 chosen from 1 choice
[ 16.592676] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 16.592821] hub 2-0:1.0: usb_probe_interface
[ 16.592836] hub 2-0:1.0: usb_probe_interface - got id
[ 16.592858] hub 2-0:1.0: USB hub found
[ 16.592888] hub 2-0:1.0: 1 port detected
[ 16.592899] hub 2-0:1.0: standalone hub
[ 16.592908] hub 2-0:1.0: individual port power switching
[ 16.592918] hub 2-0:1.0: no over-current protection
[ 16.592927] hub 2-0:1.0: Single TT
[ 16.592940] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 16.592951] hub 2-0:1.0: power on to power good time: 10ms
[ 16.592975] hub 2-0:1.0: local power source is good
[ 16.593132] hub 2-0:1.0: enabling power on all ports
[ 16.694821] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 16.694896] hub 2-0:1.0: hub_suspend
[ 16.694929] usb usb2: bus auto-suspend, wakeup 1
[ 16.763141] CAUTION: musb: Babble Interrupt Occurred
Any change when you upgrade to the latest 'bone27/28'?
If it's my root file system:
wget http://rcn-ee.net/deb/raring-armhf/v3.8.13-bone27/install-me.sh
/bin/bash install-me.sh
Thanks for the quick reply Robert. I just tried the solution you posted but still the usb is not reading any device. Is there output that I should be expecting that would help debug this?
