Hi!
I downloaded the modules and uimages available at http://www.angstrom-distribution.org/demo/beagleboard/untested/ but I am having some troubles.
When I use uImage (and respective modules) versions - 2.6.29r37 and 2.6.29r44, the usb host is not detected at all. However, my webcam (uvc-based) works fine, and can be detected through the usb-otg port.
I tried with the older version (2.6.28r17), but had the exact opposite experience. The webcam refused to be detected (ie appear as /dev/video0), and all attempts to install the uvc drivers failed. But, the usb-host itself worked fine.
Is there some way (patch/etc) to get the usb-host to be detected on the uImage 2.6.29r37 and 2.6.29r44? Or are there some newer versions that make both available?
I want to get my webcam running, and ideally would like to do it on the usb-host itself (better speeds). Has anyone got it working on the beagleboard so far (on the usb host)? I use a revC board.
Kedar
