USB host port pull-up/down status
There was some discussion at IRC [1] changing the USB host port pull-up/down status on the phy, the lock-ups have been eliminated (*).
Looking at the usb_validation_uboot_patch.diff [2] this seems to be done with something like patch in attachment.
I built a uboot with this (attachment, too), anybody likes to test? Does USB host feel better with this? Note that kernel CONFIG_OMAP_MUX has to be disabled for this, as enabled CONFIG_OMAP_MUX overwrites uboot's pin mux settings.
Dirk
(*) "but, there are still many errors in the transmissions"
[1] http://www.beagleboard.org/irclogs/index.php?date=2008-05-18#T15:21:01
[2] http://code.google.com/p/beagleboard/wiki/USBHostTestREPRODUCE
u-boot_1_1_4_usb_host_pin_mux_test.patch (2.35 KB)
u-boot.bin_usb_pin_mux_test.bz2 (145 KB)
EHCI doesn't work with this uboot regardless of CONFIG_OMAP_MUX being
enabled.
The output if lsusb in both cases is:
root@beagleboard:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 1 Device 1: ID 1d6b:0002
root@beagleboard:~#
Do more people see this behaviour?
regards,
Koen
I think we should address this problem step by step:
1) Does u-boot setup GPIOs and MUX settings correctly for the
beagleboard? (e.g. copy/paste errors from evm and sdp code)
2) Does linux[1] overwrite u-boot settings for GPIO and MUXes?
2b) Does linux setup GPIOs and MUX settings correctly for the
3) Is the PHY getting setup properly in linux?
Can anyone familiar with the u-boot and kernel GPIO/MUX macros give an
opinion on the above?
regards,
Koen
[1] When I say 'linux' I mean linux-omap git HEAD, not the wtbu kernel
For MUX settings hopefully this makes checking easier:
1. u-boot_1_1_4_beagle_pin_mux.txt (attachment)
2. linux_git_beagle_pin_mux.txt (attachment)
Note: Ball names not from OMAP3530 (?)
3. Beagle HW manual (schematic with pin/balls)
http://www.beagleboard.org/uploads/Beagle_HW_Reference_Manual_A_5.pdf
4. OMAP3 pin mux
SPRUF98.pdf, page 684, section 6.4.4.3 Pad Multiplexing Register Fields, Table 6-4
Dirk
u-boot_1_1_4_beagle_pin_mux.txt (41.9 KB)
linux_git_beagle_pin_mux.txt (9.25 KB)
4. OMAP3 pin mux
I started (not ready yet) comparing u-boot_1_1_4_beagle_pin_mux.txt with pin mux in above OMAP3 TRM. First results:
1) Empty #define CONTROL_PADCONF_ in uboot mux config definitions.
-> Copy & paste error?
2) MUX_VAL(CP(ETK_D15), (IEN | PTU | EN | M4)) /*GPIO_29*/\
is wrong. Has to be ETK_D15_ES2 to configure GPIO_29. Beagle HW manual:
"GPIO_29 SD Write protect lead. Can be polled or set to an interrupt."
With ETK_D15 we write to non existing (?) register.
3)
CONTROL_PADCONF_ETK_D11_ES2 0x05F2
CONTROL_PADCONF_ETK_D12_ES2 0x05F4
CONTROL_PADCONF_ETK_D13_ES2 0x05F6
CONTROL_PADCONF_ETK_D14_ES2 0x05F8
are not touched by uboot pin mux. Is this correct?
4)
sys_nreswarm 0x0A08
jtag_rtck 0x0A4E
jtag_tdo 0x0A50
More to come,
Dirk
