Hi All!
I’ve designed a board based on Beagleboard design with minor changes. The signal USB2HS_nRST mapped to another CPU pin rather then at the original BB. Now I need to configure this pin in the kernel (I use OE environment) but can’t find where it is actually done. I can see how USB PHY related pins are configured but don’t see the same for USB2HS_nRST.
Please help!
regards,
Max
