I am having the USB lockup issue on EHCI. seems to be triggered by
intensive cpu usage, or usb traffic. i get the following in dmesg
[48262.074157] hub 1-0:1.0: port 2 disabled by hub (EMI?), re-
enabling...
[48262.094451] usb 1-2: USB disconnect, address 2
[48262.094482] usb 1-2.1: USB disconnect, address 3
[48262.094726] usb 1-2: clear tt 1 (9031) error -71
[48262.115234] usb 1-2: clear tt 1 (9031) error -19
[48262.128662] usb 1-2: clear tt 1 (9031) error -19
[48262.145843] usb 1-2: clear tt 1 (9031) error -19
[48262.161590] eth0: unregister 'dm9601' usb-ehci-omap.0-2.1, Davicom
DM9601 USB Ethernet
[48263.474487] usb 1-2.4: USB disconnect, address 4
and then nothing on USB will work anymore. this seem to be a widely
reported issue.
i was wondering if the mini usb port (OTG) is also effected? I have
tried pluging my hub into that via a couple of different usb gender
changers, but the board does not see any devices. looks like i need to
do soldering to make it act as a host (is that right?).
if i do the soldering will i get a stable USB port? or should i just
RMA the board (bit of a pain as I am in the UK)
The capacitor can be SMT or thruhole. ESR is not super critical in this case, althogu lower is better, a higher value won’t cause any issues. After all, in this case you already have an issue. I really don’t want to get into providing a long list of parts and have to keep adding numbers because the parts I specify may not be available in a specific region. They can always send it in for an RMA and we will do it. Folks have had success soldering in a thru hole part, something more likley to be found, on the expansion connector as well across the 1.8V and ground pins on the expansion connector.
i needed make a /etc/rc2.d/S00usbhost
echo host> /sys/devices/platform/musb_hdrc/mode
sleep 5
to get it into host mode, and wait long enough to get dhcp before
starting services (mpd). /etc/rc.local is to late in the boot process.
I bought a mini-a => mini-b cable and i tried to link the bb to the
hub (which is self powered)
sleep 5
Then i tried to create that file during the boot but it fault and the
bb doesn't see any hub or device..
I gave a look to the dmesg but there isn't nothing about usb interface..
it return me an error because there is no file with that name..
i think we are using a different version of kernel and something has changed..
what is yours? i'm using the unstable prebuild image of angstrom with
a 2.6.29 kernel..
Do NOT remove C97. ADD the 22uf cap to C97. You can try adding it across C97 itself, or try adding it between the GND signal and the 1.8V rail on the expansion header.
