USB OTG as host not working with current l-o
USB OTG as host does not work with the current l-o. Does someone has a
hint why - or even a patch?
regards
florian
There are useful USB OTG hints on the BeagleBoard Wiki:
http://elinux.org/BeagleBoard#OTG
and on the BeagleBoard community FAQ:
http://elinux.org/BeagleBoardFAQ#USB_OTG_connection
Hope this helps.
Florian Limberger wrote:
USB OTG as host does not work with the current l-o. Does someone has a hint why - or even a patch?
Regards
Dirk
Måns has a patch, but that didn't seem to do the trick for me :frowning:
regards,
Koen
Koen Kooi <koen.kooi@gmail.com> writes:
But your patch does fix device-mode, right?
I presume you have grounded pin 4 (solder it to pin 5 if you never
intend to use OTG as a device), if you are using a mini-B cable, or
that you have found a true mini-A cable (which I cannot seem to
locate). We just had a discussion of this a couple days back.
Steve
Koen Kooi <koen.k...@gmail.com> writes:
I'm not using host mode.
Yes.
Could you please name the patch or commit? I could not find the patch in your git-tree (master, patches).
regards
Florian
Florian Limberger <florian.limberger@limed.at> writes:
Yes.
I believe Koen is referring to the "fix something" patch:
http://git.mansr.com/?p=linux-omap;a=commitdiff;h=1e5bc41773bb981b3a89bd762becf98c72be5e4c
I've - carefully -shortened d2 with a blank wire on the backside of
the board. ---> USB running perfectly in host-mode...
(keyboard..mouse...repeater...)
Don't forget to remove the shorting when using client mode...
h.
Yes.
It definitely "fixes something" because USB OTG in host roll is now working using the current l-o. Thx.
