I have Beagle Rev B5 board. I have connected USB mouse to the beagle board
to test the USB host capability. To configure Beagle board as USB host, I
have shorted Pin 4 and Pin 5 of USB OTG (ID pin is connected with GND). But
when I run the diagnostic software, the diagnostic application is not able
to capture the mouse event. Please find my test approach as follows:
1. Shorted Pin 4 (ID) and pin 5 (GND) of USB OTG
2. Connected USB hub to the board. (external power is given to hub)
3. Connected USB mouse to the board.
4. Power on the board.
5. Invoked the command 'evtest /dev/input/event0'
Observation:
1. In 'dmesg', I could not find the details of USB mouse.
2. When the 'evtest' command is executed, it shows vendor and product id as
0x00. This confirms that the Beagle has not recognized the USB mouse.
3. With this set-up, I have connected the beagle board to Windows Desktop, I
have not seen "Device Name: Linux USB Ethernet/RNDIS Gadget." This confirms
that the USB is configured as host.
I would like to know whether the Beagle board Rev B5 work as host controller
and it can communicate with USB devices like mouse, Ethernet etc.Pls help me
in resolving this issue.
Note:
1. I have successfully tested USB OTG as peripheral. I have followed the
instructions mentioned in
http://code.google.com/p/beagleboard/wiki/BeagleBoardDiagnostics
Maniyan
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments contained in it.
