Is it posible to test USB_OTG as peripheral by using miniB cable on RevB5 beagleboard.
Thanks & Regards
Tilak
Thanks & Regards
Tilak
Yes.
Hypothetic question, but perhaps you know the answer: will it be
possible with Rev. C to use the miniB as OTG and to use the second
USB-connector for connecting peripherials at the same time?
Robert
RevB5 beagleboard.Yes.
That will be possible.
Thats great! Really great! This opens a lot of possibilities! Works
this out of the box with the kernel or has something to be done?
Robert
USB-connector for connecting peripherials at the same time?That will be possible.
...I mean, will it be out of the box possible to use the BB as
gadget/device with the miniB and to connect a mouse/keyboard to the
oterh port?
Robert
this out of the box with the kernel or has something to be done?...I mean, will it be out of the box possible to use the BB as
oterh port?
Only with a hub, the EHCI port only supports fullspeed devices and needs a hub for low- and high-speed devices.
regards,
Koen
oterh port?Only with a hub, the EHCI port only supports fullspeed devices and needs a
Okay, that should be no problem for me: using a hub or only connect a
fullspeed device.
Thanks for the answer, these are very great news.
Robert
Minor correction - Just to be totally clear, since USB terminology is tricky
EHCI => High Speed = 480Mbps
OHCI and UHCI => Full Speed = 12 Mbps
OHCI and UHCI => Low Speed = 1.5 Mbps
The EHCI port therefore only support High speed and needs a hub to connect
to full and/or low speed devices...
Best regards
Søren
-----Oprindelig meddelelse-----
My device is EHCI, so this fits exactly. And its a fantastic
possibility to connect the BB to windows and establish a network
connection at the same time
Robert
Hi Robert,
Just to be totally clear – EHCI (480Mbps) and UHCI/OHCI (1.5 and/or 12Mbps)
are host controller types and thereby only valid for USB hosts...
A device is either Low, Full or High speed compliant and not E/U/OHCI...
I think that what you mean is, that your device is a High speed compliant
and therefore fits directly - Right?
Best regards – Enjoy your weekends everybody
Søren
Right
Does, this mean Beagle Rev C has two separate USB controllers inside?
i.e. Separate controller for OTG and USB Host.
Shivdas
Hi Shivdas,
You are completely right
Søren
