We are using Beagle board rev.B4. As beagle board doesn't have
ethernet support, we are using 'AIRKLINK101'-USB to Ethernet adapter.
Its driver is already present in kernel. We also want to use USB
pendrive simultaneously. So we use HUB to which both the devices are
connected. HUB and Beagle board are self powered, and HUB is connected
to USB OTG connector of beagle board. This is our setup.
Problem?
1. Bring up the ethernet interface, and mount NFS file system.
2. Mount USB pendrive in FS (into ramdisk directory)
3. Mount MMC card (into ramdisk directory)
4. Once all are mounted (in any sequence), if I try to copy from any
mounted directory to the other. Kernel crashes.
5. If only pendrive or ethernet adapter is used, sytem works fine
without crash.
6. Sometimes kernel crashes while mounting pendrive or NFS itself.
7. Similar issue is not there on OMAP3 OSK board (EVM).
Questions?
1. Is there any issue with Beagle board to work with two different USB
devices connected to it (through HUB)?
2. I compared USB driver codes of both the Beagle board and OMAP3 OSK
board. There are differences in files present in '/usb/musb' folder.
Can I try replacing those files directly from OSK linux USB driver? or
any more changes are required? Will it cause any other issues?
3. Has anybody faced similar issue? If anyone has some pointer
regarding this, please let me know.
I am attaching kernel log along with this post.
Regards
Satyajit
