I have two issues running my beagleboard-xm
1.When I connect beagleboard xm via otg cable i do not get any device created on my 10.10 machine when i check dmesg i get this
[251813.848052] usb 2-5: new high speed USB device using ehci_hcd and address 17
[251816.982261] usb 2-5: USB disconnect, address 17
and lsusb gives texas instrument device for 1 sec and goes away
also,
when i connect xm through serial cable without any mmc in it, it gives garbage on minicom
What might be the problem?
Thanks in advance
If you leave out the SD the board will never boot. It has no boot source. The garbage as you call it is normal when it has no place to boot from. It is looking for a boot source via the serial port.
I suggest you put the SD card that shipped with the board back into the board.
