USB over Ethernet does not work, only USB mass device
Hi, I have pluggeg in a new BB Black to Linux Mint, once LM 18.1, now some older version, but the results are similar. The mass device connects instantly, the leds blink, but there is nothing at 192.168.7.2. I attach ifconfig, then syslog.
Du you know what might be the problem?
eth0 Link encap:Ethernet HWaddr 00:19:99:e8:64:40
inet addr:192.168.100.4 Bcast:192.168.100.255 Mask:255.255.255.0
inet6 addr: fe80::219:99ff:fee8:6440/64 Scope:Link
RX packets:2098119 errors:0 dropped:0 overruns:0 frame:0
TX packets:1165704 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2883043840 (2.8 GB) TX bytes:87011521 (87.0 MB)
eth1 Link encap:Ethernet HWaddr 60:64:05:fe:ff:6b
inet6 addr: fe80::6264:5ff:fefe:ff6b/64 Scope:Link
RX packets:46 errors:3 dropped:0 overruns:0 frame:3
TX packets:187 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:10507 (10.5 KB) TX bytes:45720 (45.7 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2842 errors:0 dropped:0 overruns:0 frame:0
TX packets:2842 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
Dec 23 23:48:19 nebula kernel: [12222.187206] usb 2-1.1: new high-speed USB device number 37 using ehci-pci
Dec 23 23:48:19 nebula kernel: [12222.280513] usb 2-1.1: New USB device found, idVendor=1d6b, idProduct=0104
Dec 23 23:48:19 nebula kernel: [12222.280518] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=5
Dec 23 23:48:19 nebula kernel: [12222.280521] usb 2-1.1: Product: BeagleBoneBlack
Dec 23 23:48:19 nebula kernel: [12222.280523] usb 2-1.1: Manufacturer: Circuitco
Dec 23 23:48:19 nebula kernel: [12222.280525] usb 2-1.1: SerialNumber: A0-4816BBBK2EBD
Dec 23 23:48:19 nebula kernel: [12222.283290] rndis_host 2-1.1:1.0 eth1: register ‘rndis_host’ at usb-0000:00:1d.0-1.1, RNDIS device, 60:64:05:fe:ff:6b
Dec 23 23:48:19 nebula kernel: [12222.283774] cdc_acm 2-1.1:1.2: This device cannot do calls on its own. It is not a modem.
Dec 23 23:48:19 nebula kernel: [12222.283824] cdc_acm 2-1.1:1.2: ttyACM0: USB ACM device
Dec 23 23:48:19 nebula kernel: [12222.284525] usb-storage 2-1.1:1.4: USB Mass Storage device detected
Dec 23 23:48:19 nebula kernel: [12222.284720] scsi21 : usb-storage 2-1.1:1.4
Dec 23 23:48:19 nebula mtp-probe: checking bus 2, device 37: “/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1”
Dec 23 23:48:19 nebula mtp-probe: bus: 2, device: 37 was not an MTP device
Dec 23 23:48:19 nebula NetworkManager[2704]: failed to allocate link cache: (-12) Object not found
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): carrier is OFF
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): new Ethernet device (driver: ‘rndis_host’ ifindex: 20)
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): exported as /org/freedesktop/NetworkManager/Devices/17
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): device state change: unmanaged → unavailable (reason ‘managed’) [10 20 2]
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): bringing up device.
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): carrier now ON (device state 20)
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): preparing device.
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): deactivating device (reason ‘managed’) [2]
Dec 23 23:48:19 nebula NetworkManager[2704]: Added default wired connection ‘Wired connection 1’ for /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/net/eth1
Dec 23 23:48:19 nebula NetworkManager[2704]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/net/eth1, iface: eth1)
Dec 23 23:48:19 nebula NetworkManager[2704]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/net/eth1, iface: eth1): no ifupdown configuration found.
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): device state change: unavailable → disconnected (reason ‘none’) [20 30 0]
Dec 23 23:48:19 nebula NetworkManager[2704]: Auto-activating connection ‘Wired connection 1’.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) starting connection ‘Wired connection 1’
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): device state change: disconnected → prepare (reason ‘none’) [30 40 0]
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled…
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) started…
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) scheduled…
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) starting…
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): device state change: prepare → config (reason ‘none’) [40 50 0]
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) successful.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) started…
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): device state change: config → ip-config (reason ‘none’) [50 70 0]
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Dec 23 23:48:19 nebula dhclient: Internet Systems Consortium DHCP Client 4.2.4
Dec 23 23:48:19 nebula dhclient: Copyright 2004-2012 Internet Systems Consortium.
Dec 23 23:48:19 nebula dhclient: All rights reserved.
Dec 23 23:48:19 nebula dhclient: For info, please visit https://www.isc.org/software/dhcp/
Dec 23 23:48:19 nebula NetworkManager[2704]: dhclient started with pid 7931
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Beginning IP6 addrconf.
Dec 23 23:48:19 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Dec 23 23:48:19 nebula dhclient: Listening on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:48:19 nebula dhclient: Sending on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:48:19 nebula dhclient: Sending on Socket/fallback
Dec 23 23:48:19 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 (xid=0x6c026718)
Dec 23 23:48:19 nebula NetworkManager[2704]: (eth1): DHCPv4 state changed nbi → preinit
Dec 23 23:48:20 nebula kernel: [12223.284274] scsi 21:0:0:0: Direct-Access Linux File-Stor Gadget 0401 PQ: 0 ANSI: 2
Dec 23 23:48:20 nebula kernel: [12223.284665] sd 21:0:0:0: Attached scsi generic sg6 type 0
Dec 23 23:48:20 nebula kernel: [12223.286348] sd 21:0:0:0: [sdf] 81920 512-byte logical blocks: (41.9 MB/40.0 MiB)
Dec 23 23:48:20 nebula kernel: [12223.287400] sd 21:0:0:0: [sdf] Write Protect is off
Dec 23 23:48:20 nebula kernel: [12223.287406] sd 21:0:0:0: [sdf] Mode Sense: 0f 00 00 00
Dec 23 23:48:20 nebula kernel: [12223.289489] sd 21:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Dec 23 23:48:20 nebula kernel: [12223.314288] sdf: sdf1
Dec 23 23:48:20 nebula kernel: [12223.346760] sd 21:0:0:0: [sdf] Attached SCSI removable disk
Dec 23 23:48:20 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:48:20 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:48:20 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1..
Dec 23 23:48:22 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 (xid=0x6c026718)
Dec 23 23:48:29 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 10 (xid=0x6c026718)
Dec 23 23:48:34 nebula ModemManager[2682]: Creating modem with plugin ‘Generic’ and ‘2’ ports
Dec 23 23:48:34 nebula ModemManager[2682]: Could not grab port (tty/ttyACM0): ‘Cannot add port ‘tty/ttyACM0’, unhandled serial type’
Dec 23 23:48:34 nebula ModemManager[2682]: Couldn’t create modem for device at ‘/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1’: Failed to find primary AT port
Dec 23 23:48:39 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13 (xid=0x6c026718)
Dec 23 23:48:39 nebula NetworkManager[2704]: (eth1): IP6 addrconf timed out or failed.
Dec 23 23:48:39 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) scheduled…
Dec 23 23:48:39 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) started…
Dec 23 23:48:39 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Dec 23 23:48:52 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15 (xid=0x6c026718)
Dec 23 23:49:04 nebula NetworkManager[2704]: (eth1): DHCPv4 request timed out.
Dec 23 23:49:05 nebula NetworkManager[2704]: (eth1): canceled DHCP transaction, DHCP client pid 7931
Dec 23 23:49:05 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) scheduled…
Dec 23 23:49:05 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) started…
Dec 23 23:49:05 nebula NetworkManager[2704]: (eth1): device state change: ip-config → failed (reason ‘ip-config-unavailable’) [70 120 5]
Dec 23 23:49:05 nebula NetworkManager[2704]: Activation (eth1) failed for connection ‘Wired connection 1’
Dec 23 23:49:05 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) complete.
Dec 23 23:49:05 nebula NetworkManager[2704]: (eth1): device state change: failed → disconnected (reason ‘none’) [120 30 0]
Dec 23 23:49:05 nebula NetworkManager[2704]: (eth1): deactivating device (reason ‘none’) [0]
Dec 23 23:49:05 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:05 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:05 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:49:06 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:06 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:49:06 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:07 nebula NetworkManager[2704]: Auto-activating connection ‘Wired connection 1’.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) starting connection ‘Wired connection 1’
Dec 23 23:49:07 nebula NetworkManager[2704]: (eth1): device state change: disconnected → prepare (reason ‘none’) [30 40 0]
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled…
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) started…
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) scheduled…
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) starting…
Dec 23 23:49:07 nebula NetworkManager[2704]: (eth1): device state change: prepare → config (reason ‘none’) [40 50 0]
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) successful.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) started…
Dec 23 23:49:07 nebula NetworkManager[2704]: (eth1): device state change: config → ip-config (reason ‘none’) [50 70 0]
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Dec 23 23:49:07 nebula NetworkManager[2704]: dhclient started with pid 7948
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Beginning IP6 addrconf.
Dec 23 23:49:07 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:07 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:07 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:49:07 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Dec 23 23:49:07 nebula dhclient: Internet Systems Consortium DHCP Client 4.2.4
Dec 23 23:49:07 nebula dhclient: Copyright 2004-2012 Internet Systems Consortium.
Dec 23 23:49:07 nebula dhclient: All rights reserved.
Dec 23 23:49:07 nebula dhclient: For info, please visit https://www.isc.org/software/dhcp/
Dec 23 23:49:07 nebula NetworkManager[2704]: (eth1): DHCPv4 state changed nbi → preinit
Dec 23 23:49:07 nebula dhclient: Listening on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:49:07 nebula dhclient: Sending on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:49:07 nebula dhclient: Sending on Socket/fallback
Dec 23 23:49:07 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 (xid=0xcb43b33e)
Dec 23 23:49:09 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:09 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:49:09 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1..
Dec 23 23:49:10 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 8 (xid=0xcb43b33e)
Dec 23 23:49:18 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 11 (xid=0xcb43b33e)
Dec 23 23:49:27 nebula NetworkManager[2704]: (eth1): IP6 addrconf timed out or failed.
Dec 23 23:49:27 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) scheduled…
Dec 23 23:49:27 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) started…
Dec 23 23:49:27 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Dec 23 23:49:29 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7 (xid=0xcb43b33e)
Dec 23 23:49:36 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13 (xid=0xcb43b33e)
Dec 23 23:49:49 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 20 (xid=0xcb43b33e)
Dec 23 23:49:52 nebula NetworkManager[2704]: (eth1): DHCPv4 request timed out.
Dec 23 23:49:53 nebula NetworkManager[2704]: (eth1): canceled DHCP transaction, DHCP client pid 7948
Dec 23 23:49:53 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) scheduled…
Dec 23 23:49:53 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) started…
Dec 23 23:49:53 nebula NetworkManager[2704]: (eth1): device state change: ip-config → failed (reason ‘ip-config-unavailable’) [70 120 5]
Dec 23 23:49:53 nebula NetworkManager[2704]: Activation (eth1) failed for connection ‘Wired connection 1’
Dec 23 23:49:53 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) complete.
Dec 23 23:49:53 nebula NetworkManager[2704]: (eth1): device state change: failed → disconnected (reason ‘none’) [120 30 0]
Dec 23 23:49:53 nebula NetworkManager[2704]: (eth1): deactivating device (reason ‘none’) [0]
Dec 23 23:49:53 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:53 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:53 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:49:55 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:55 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:49:55 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:55 nebula NetworkManager[2704]: Auto-activating connection ‘Wired connection 1’.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) starting connection ‘Wired connection 1’
Dec 23 23:49:55 nebula NetworkManager[2704]: (eth1): device state change: disconnected → prepare (reason ‘none’) [30 40 0]
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled…
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) started…
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) scheduled…
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) starting…
Dec 23 23:49:55 nebula NetworkManager[2704]: (eth1): device state change: prepare → config (reason ‘none’) [40 50 0]
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) successful.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) started…
Dec 23 23:49:55 nebula NetworkManager[2704]: (eth1): device state change: config → ip-config (reason ‘none’) [50 70 0]
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Dec 23 23:49:55 nebula NetworkManager[2704]: dhclient started with pid 7954
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Beginning IP6 addrconf.
Dec 23 23:49:55 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:49:55 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:55 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:49:55 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Dec 23 23:49:55 nebula dhclient: Internet Systems Consortium DHCP Client 4.2.4
Dec 23 23:49:55 nebula dhclient: Copyright 2004-2012 Internet Systems Consortium.
Dec 23 23:49:55 nebula dhclient: All rights reserved.
Dec 23 23:49:55 nebula dhclient: For info, please visit https://www.isc.org/software/dhcp/
Dec 23 23:49:55 nebula NetworkManager[2704]: (eth1): DHCPv4 state changed nbi → preinit
Dec 23 23:49:55 nebula dhclient: Listening on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:49:55 nebula dhclient: Sending on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:49:55 nebula dhclient: Sending on Socket/fallback
Dec 23 23:49:55 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 (xid=0x55e5382b)
Dec 23 23:49:56 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:49:56 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:49:56 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1..
Dec 23 23:49:58 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5 (xid=0x55e5382b)
Dec 23 23:50:03 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 13 (xid=0x55e5382b)
Dec 23 23:50:15 nebula NetworkManager[2704]: (eth1): IP6 addrconf timed out or failed.
Dec 23 23:50:15 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) scheduled…
Dec 23 23:50:15 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) started…
Dec 23 23:50:15 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Dec 23 23:50:16 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12 (xid=0x55e5382b)
Dec 23 23:50:28 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 15 (xid=0x55e5382b)
Dec 23 23:50:40 nebula NetworkManager[2704]: (eth1): DHCPv4 request timed out.
Dec 23 23:50:41 nebula NetworkManager[2704]: (eth1): canceled DHCP transaction, DHCP client pid 7954
Dec 23 23:50:41 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) scheduled…
Dec 23 23:50:41 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) started…
Dec 23 23:50:41 nebula NetworkManager[2704]: (eth1): device state change: ip-config → failed (reason ‘ip-config-unavailable’) [70 120 5]
Dec 23 23:50:41 nebula NetworkManager[2704]: Activation (eth1) failed for connection ‘Wired connection 1’
Dec 23 23:50:41 nebula NetworkManager[2704]: Activation (eth1) Stage 4 of 5 (IPv4 Configure Timeout) complete.
Dec 23 23:50:41 nebula NetworkManager[2704]: (eth1): device state change: failed → disconnected (reason ‘none’) [120 30 0]
Dec 23 23:50:41 nebula NetworkManager[2704]: (eth1): deactivating device (reason ‘none’) [0]
Dec 23 23:50:41 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:50:41 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:50:41 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:50:42 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:50:42 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:50:42 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:50:43 nebula NetworkManager[2704]: Auto-activating connection ‘Wired connection 1’.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) starting connection ‘Wired connection 1’
Dec 23 23:50:43 nebula NetworkManager[2704]: (eth1): device state change: disconnected → prepare (reason ‘none’) [30 40 0]
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) scheduled…
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) started…
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) scheduled…
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 1 of 5 (Device Prepare) complete.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) starting…
Dec 23 23:50:43 nebula NetworkManager[2704]: (eth1): device state change: prepare → config (reason ‘none’) [40 50 0]
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) successful.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 2 of 5 (Device Configure) complete.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) started…
Dec 23 23:50:43 nebula NetworkManager[2704]: (eth1): device state change: config → ip-config (reason ‘none’) [50 70 0]
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Beginning DHCPv4 transaction (timeout in 45 seconds)
Dec 23 23:50:43 nebula NetworkManager[2704]: dhclient started with pid 7957
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Beginning IP6 addrconf.
Dec 23 23:50:43 nebula avahi-daemon[913]: Withdrawing address record for fe80::6264:5ff:fefe:ff6b on eth1.
Dec 23 23:50:43 nebula avahi-daemon[913]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:50:43 nebula avahi-daemon[913]: Interface eth1.IPv6 no longer relevant for mDNS.
Dec 23 23:50:43 nebula NetworkManager[2704]: Activation (eth1) Stage 3 of 5 (IP Configure Start) complete.
Dec 23 23:50:43 nebula dhclient: Internet Systems Consortium DHCP Client 4.2.4
Dec 23 23:50:43 nebula dhclient: Copyright 2004-2012 Internet Systems Consortium.
Dec 23 23:50:43 nebula dhclient: All rights reserved.
Dec 23 23:50:43 nebula dhclient: For info, please visit https://www.isc.org/software/dhcp/
Dec 23 23:50:43 nebula NetworkManager[2704]: (eth1): DHCPv4 state changed nbi → preinit
Dec 23 23:50:43 nebula dhclient: Listening on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:50:43 nebula dhclient: Sending on LPF/eth1/60:64:05:fe:ff:6b
Dec 23 23:50:43 nebula dhclient: Sending on Socket/fallback
Dec 23 23:50:43 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 (xid=0x9e70a00f)
Dec 23 23:50:45 nebula avahi-daemon[913]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::6264:5ff:fefe:ff6b.
Dec 23 23:50:45 nebula avahi-daemon[913]: New relevant interface eth1.IPv6 for mDNS.
Dec 23 23:50:45 nebula avahi-daemon[913]: Registering new address record for fe80::6264:5ff:fefe:ff6b on eth1.*.
Dec 23 23:50:46 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5 (xid=0x9e70a00f)
Dec 23 23:50:51 nebula dhclient: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 12 (xid=0x9e70a00f)
Please reflash
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Jessie_Snapshot_lxqt
There was an issue with usb0 that i had solved last week.. (race
condition during the setup of wlan0)
Thanks Robert for fixing this. However, I use this lcd cape:
http://pl.farnell.com/element14/bb-cape-disp-ct43/display-board-tft-lcd-beaglebone/dp/2526164
for which I need “temporarily” a custom image: https://www.element14.com/community/docs/DOC-81966
“The intention is to provision and release an official beagleboard.org supported firmware image that will be posted
to beagleboard.org’s firmware images page”
which also does not bring usb0.
I wonder if the image which you linked might already support the cape? I think that I will just flash that image and not use
the lcd for now.
Oh that lcd/board combination is supported, with a couple small tweaks..
Grab the lxqt-4gb image, and boot..
Login and change:
/boot/uEnv.txt
dtb=am335x-boneblack-overlay.dtb
and also run:
sudo apt update ; sudo apt upgrade
as another user just solved the lightdm startup issue today, so that
was just pushed to the repo..
(this sunday's snapshot will have that package updated by default)
and we are a few weeks away from making that cape work out of the box
(all lcd3/lcd4/lcd7 capes)
I flashed the new image and the board started to work correctly, both mass device and Ethernet over USB. However, after disabling HDMI and eMMc as you suggested, none of these two shows up, as if the board weren’t connected at all.
Is it that “disable eMMC” disables eMMC completely, so that not it does not work as a boot partition? Should I thus always boot from the card if I want to use the cape? Yes, the card keeps reflashing eMMC. rootfs mounts readonly to PC sot
that I can not disable the reflashing. What should I do?
“Yet, the card…”
I would guess trhat it is like that: I should reflash the eMMC with eMMC/HDMI enabled. Then, as rootfs being an image is readonly, I should download the non-flashing version and boot from it if I want to use the lcd card. HDMI/eMMC should be disabled but only on the card. What is the exact purpose of the boot button if Beagleboard can boots from the card even if the button is not pressed?
Ok, I found the docs and the new Debian works fine with the cape. Thanks!
Sorry, yeah if you want to use the eMMC you'll need:
dtb=am335x-boneblack-emmc-overlay.dtb
