USB (power) cable for BeagleBone Rev5A
Hello All,
I’ve misplaced my USB cable that came along with my Beaglebone RevA5,
I’ve looked for a suitable cable in Fry’s and Radio Shack, can’t find one.
What is the type of cable that I can use and where can I buy one ?
Regards
Cyril
Did you read the System Reference Manual? It has that information in the manual.
http://circuitco.com/support/index.php?title=BeagleBone
Thanks Gerald and Special Computing.
It was my bad. I had the right cable, but due the clearance between the usb connector and the casing for the BB the cable would not go in.
So I thought I had a incorrect cable and did not want to force it. After reading the SRM again and removing the BB from the casing I was able easily insert the
usb cable. I removed some plastic around the cable and now fits fine with my casing on.
Thanks again for the help.
Regards
Cyril
