USB/serial converters, and upcoming dumb questions
in prep for a presentation i want to give later this year on the
beagleboard, i'm going to have a number of upcoming (possibly
seriously dumb) questions, just so i know i can answer them if someone
asks *me*. so be patient, please.
  first, does anyone have a USB/serial converter working to talk their
BB? as most folks know, new systems typically don't have serial
ports, so you typically need to use a USB solution to connect to the
BB console.
  at the moment, i have:
  USB port ->
    targus port replicator ->
      outgoing serial port with null modem cable ->
        everex AT cable ->
          BB console port
and that works fine, with minicom humming right along on my fedora 11
(preview system).
  to cut down the tangle, i tried to replace the targus port
replicator with a no-name USB/serial converter going straight from the
host USB port to the null modem cable. when i plug it in, hotplug
loads the "pl2303" kernel module, but i have yet to get this to work
-- what i get via minicom is unprintable junk spewed out, as if the
baud rate is wrong or something.
  targus port replicator: totally reliable. USB/serial converter:
hasn't worked yet. this may well be a fedora issue, so i'm interested
if anyone has one of these working under a different host distro, so i
can file a bug report against fedora about it. thanks.
rday
I use no name usb to serial adapters with Fedora without any trouble.
I am using kermit though.
Philip
* you still need the null modem cable, right?
  * do you know which kernel module is loaded to support that
    converter when you plug it in?
rday
> interested if anyone has one of these working under a different
> host distro, so i can file a bug report against fedora about it.
> thanks.
trouble. I am using kermit though.
Yes.
Er, never looked ...
nothing in lsmod is jumping out at me. I'll check closer next time I
can easily unlplug the adapter.
Philip
for me, it was "pl2303", the Prolific serial adapter driver. i was
just curious if your insertion loaded something else, which might help
me debug what's happening.
rday
Bus 002 Device 003: ID 9710:7720 MosChip Semiconductor
Bus 002 Device 002: ID 9710:7720 MosChip Semiconductor
Is what I see. I have two double serial units for four serial ports.
Philip
help
I know of 3 major USB2UART converter chip-manufacturers, although others
exist as well:
1) FTDI-chip
2) MosChip
3) Prolific
In general I have never had any trouble using FTDI. MosChip has troubled me
a single time, and Prolific several, although I can't really tell what's the
main difference between the different chips. I think most of the problems
(if not all) are SW-related, but I would definitely aim at a FTDI solution
in case I can choose myself :slight_smile:
That was my 5 cent
  Søren
help
exist as well:
1) FTDI-chip
2) MosChip
3) Prolific
That was my 5 cent
Søren
FTDI is very good. ( 10 out of zero to ten ) I have also had success with IOGear ( 8 out of zero to ten ).
Gus
