USB success & challenges
Success: I realized I had one of those little Cisco USB-Ethernet
sticks in my briefcase! Pulled it out, plugged it in, and I'm posting
Challenge: Is Angstrom meant to work with UVC cameras like the
Logitech 9000, or do I need to extend my build? The camera appears in
"lsusb" but I can't seem to get the OpenCV samples to capture from
it...
kb
(yes, I am excited!)
UVC cams work with angstrom. (haven't tried this myself)
I have tried both Logitech 9000 and Logitech Quickcam Vision Pro (same
Cam, different Firmware, I think) and they both work like a charm.
Tested on BB Rev B5 (noticing a little USB-OTG-Bandwidth problem the
last time I tried) and (recently) Rev C2. The software I tried (e.g.
for Rev C2) was
mplayer tv:// -tv driver=v4l2:width=920:height=760:device=/dev/video0 -
fps 30 -vo sdl
and a little self-written v4l2 App. You could try mplayer to see if
you can capture at all... if you are capturing over OTG, you should
try to start with 320x240 and go up from there. Worked on kernel
2.6.27, 2.6.28 and 2.6.29 so far.
Matthias
Thanks! Sadly I don't show any device named /dev/video0 or anything
similar... hmm
I'm running a narcissus build from last week, on rev c2.
mplayer does try, but quickly fails to find /dev/video0. Any
suggestions?
thx again,
kb
note that non uvc cams might have issues. I've not been able to get my
webcam properly working. This one uses the pwc driver but apparently
some data is lost or corrupted. The same cam works perfectly under
opensuse.
FM
Is the uvc module loaded? I don't think it it compiled in, so you
might need to modprobe it
FM
Thx for the suggestion, modprobe fails though, saying it can't find /
lib/modules/2.6.29/modules.dep
Looking in /lib/modules, I see three directories:
   /lib/modules/2.6.2[789]-omap1/
though none of those contain modules.dep either.
Is there some option I could use for a narcissus build? I'm currently
in the midst of trying to build Angstrom myself under Ubuntu 9.0.4,
though I've so far had two failures (#1 ran out of disk space, #2
tried on an external disk but it failed for unknown reasons -- running
#3 now with better logging, but as you may know each build can take
ten or twelve hours each! heh)
Matthias, did you need to install anything special?
thanks,
kb
insmod /libmodules/2.6.29/ernel/drivers/media/video/uvc/uvcvideo.ko
kernel might do the trick.
Not sure if additional modules are needed, but if the insmod fails
with unknown symbol this is definitely the case
guess some video modlues might also be needed.
after doing that you might want to run a depmod -a but I am not really
a modules wizard.
Rebuild time depends on your hardware. For me (dual core D920, 3 Ghz,
2 GB ram, 2 years old, opensuse, a bake of console-image from scratch
definitely takes less than 6 hrs (not counting download time, I
already had a lot of stuff in my downloads).
out of space used to happen for me as well. Make some room :slight_smile:
external disk: I vaguely recall that there could be issues with
symlinks in the path. Not sure if this is still true.
The fact that it is external should not make a difference.
We need an error message to be able to diagnose this (and for a quick
answer you could try #beagle on freenode irc).
No need to start from scratch after a build. If you try again it will
just continue where it was.
Good luck. FM.
Op 17 mei 2009, om 09:53 heeft Frans Meulenbroeks het volgende geschreven:
Most people mount those with -o user, which implies the 'noexec' flag. Figuring out the implications are left as an excercise to the reader :slight_smile:
regards,
Koen
Nothing special, as far as I remember. The last try was with a narcissus image built on wednesday last week. I have the habit of checking the “All kernel modules” option when creating the images… maybe that’s it, if you haven’t tried it already? The modules get loaded automatically when my cam is plugged in. No modprobing required. I recall, that there are problems with older models of the Quickcam 9000 under Linux. Have you tried the cam on a Linux-PC?
Matthias
thanks, I'll do that.
The cam is new this week, and the first thing I did with it is connect
o my nadros Eee - worked perfectly without effort
off to narcissus-- thx!
kb
You mean, people actually *use* mount options? Wauw.
For 25 years I just used:
mount /dev/whatever /mnt
always served me well. Only option that is sometimes needed is -t )
(ok I admit, a notable exception is mounting a SMB/CIFS share, which
is a pain-in-the-ass when it comes to credentials etc.
FM
Actually by "external" I just meant the system's second drive, since
the boot drive (with my home directory) is old and small :slight_smile:
Still having compile troubles though so I'm guessing (when I get back
to that machine) that I'll have to move the home directory to that
second drive, rather than just setting $OE_HOME and hoping it all
sorts itself.
kb
The basic issues with narcissus versus my Begle have finally been
solved thanks to Koen & Dan (see
http://groups.google.com/group/beagleboard/browse_thread/thread/b1c6396ba57bb722?hl=en#
Running
mplayer tv:// -tv driver=v4l2:width=920:height=760:device=/dev/video0-
fps 30 -vo sdl
and indeed it sees my camera right away!!!!! mplayer starts, the vid
cam "on" LED lights up, and... I get a black screen. Switching to res
320x240 makes no difference. Does the "tv://" specification mean that
the output is going to the S-Video port, rather than the HDMI/X
display, perhaps?
(next message: will try to copy-and-paste an mplayer log, since my BB
i once agan seeing both video and the internet, so I can switch
machines...)
thanks
kb
Here is the mplayer log, as you can see it seems to be lacking a few
files. I also tried using the "-vf screenshot" video filter and
pressing "s" a few times, but saw no results -- maybe it was only
copying to the clipboard, or to some location I've yet to figure out?
thx again, kb
(configuration: using narcissus, with "beagleboard demo" and "opencv"
both selected... for not, this time, "all kernel modules")
---- log begins --
bjorke@beagleboard:~$ mplayer tv://
driver=v4l2:width=320:height=240:device=/dev
/video0 -fps 30 -vo sdl
MPlayer dev-SVN-r28346-4.3.3 (C) 2000-2009 MPlayer Team
CPU: ARM
Playing tv://.
TV file format detected.
Selected driver: v4l2
name: Video 4 Linux 2 input
author: Martin Olschewski <olschewski@zpr.uni-koeln.de>
comment: first try, more to come :wink:
v4l2: your device driver does not support VIDIOC_G_STD ioctl,
VIDIOC_G_PARM was used instead.
Selected device: UVC Camera (046d:0990)
Capabilites: video capture streaming
supported norms:
inputs: 0 = Camera 1;
Current input: 0
Current format: YUYV
v4l2: ioctl set format failed: Invalid argument
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
v4l2: ioctl enum norm failed: Invalid argument
Error: Cannot set norm!
Selected input hasn't got a tuner!
v4l2: ioctl set mute failed: Invalid argument
v4l2: ioctl query control failed: Invalid argument
thx again, kb
---- log begins --
CPU: ARM
Playing tv://.
supported norms:
Current input: 0
Opening video decoder: [raw] RAW Uncompressed Video
VDec: vo config request - 640 x 480 (preferred colorspace: Packed
YUY2)
VDec: using Packed YUY2 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 640x480 => 640x480 Packed YUY2
Selected video codec: [rawyuy2] vfm: raw (RAW YUY2)
Audio: no sound
Starting playback...
v4l2: select timeout
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
v4l2: 58 frames successfully processed, -57 frames dropped.
Exiting... (Quit)
I've been able to use mplayer and my webcam by using this command:
mplayer tv:// -tv driver=v4l2:width=320:height=240:fps=90:device=/dev/video0 -nosound
Try that. It's slightly different from what you've been doing.
- Dan
Thanks again Dan. Sadly, I still get the same result... same messages
in the log, too.
WIll keep poking at it...
kb
in the log, too.
kb
You're welcome. Which webcam/driver are you using?
- Dan
camera: A new Logitech 9000 which is UVC and works swimmingly under
windows, ubuntu, and xandros on my other machines
driver: v4l2
Running 'facedetect' also lights up the camera LED and it *seems* to
be doing something though no image is displayed. It might be
delivering noise but I get the impression that it's processing
multiple frames.
I'll try using a different Angstrom SD with all kernels added later on
tonight....
kb
-- facedetect log --
bjorke@beagleboard:~$ facedetect --cascade="cascade/
haarcascade_frontalface_alt.
xml"
/usr/share/themes/Clearlooks/gtk-2.0/gtkrc:46: Clearlooks
configuration option "menuitemstyle" is not supported and will be
ignored.
/usr/share/themes/Clearlooks/gtk-2.0/gtkrc:47: Clearlooks
configuration option "listviewitemstyle" is not supported and will be
ignored.
/usr/share/themes/Clearlooks/gtk-2.0/gtkrc:48: Clearlooks
configuration option "progressbarstyle" is not supported and will be
ignored.
detection time = 8539.15ms
detection time = 8554.2ms
detection time = 11761.4ms
Camera decode error (-1): Corrupt JPEG data: premature end of data
segment
Wow, what an unexpected change:
I made a new image with the same setup but with "All Kernel Modules"
checked.
Copied it to a new card (2MB, the large partition expanded by gparted
before un-tarballing)
Launched in Beagle-- started right up
BUT: no "lsusb" available (even as root), no internet connectivity, no
sign of the video device in /dev/... It was, to my surprise, a step
BACK in terms of USB functionality. Stranger and stranger....
kb
