USB support in U-Boot?
I was trying with custom build u-boot for beagleboard.
But it seems that support for USB has not been compiled-in by default (as there is no command related to USB).
Basically I want my USB stick to get detected in U-Boot (not in kernel).
Does anybody has tried with enabling support for USB in u-boot? There are some macros in the code that needs to be defined, but which one i am not sure.
Please ,if possible, put some light on this.
~cnanda
There is no OMAP3 USB support in U-Boot mainline. There are some patches floating around, but they are not applied yet:
http://lists.denx.de/pipermail/u-boot/2009-October/063534.html
Most probably they won't help you accessing an USB stick, though, as they are USB tty only (?). Why do you need to detect an USB stick in U-Boot?
Best regards
Dirk
sure.
Most probably they won’t help you accessing an USB stick, though, as they are USB tty only (?). Why do you need to detect an USB stick in U-Boot?
Thanks, for the info.
I intended to learn USB functionality and thought learning USB functionality through U-Boot would probably be easier as their would be bare minimum support for USB driver in u-boot.
~cnanda
