USB to Ethernet adaptor
Hi guys,
I intend to get a USB to ethernet adaptor but im not sure if it will
work. May i ask which brand you guys use and what are the commands
needed for angstrom to detect the device?
Thanks a lot
Calvin
I had problems with 2 different UA0025C, USB 2.0 Fast Ethernet Adapter
form Logilink. I would try that one again.
The one that I have been using is this following one:
USB zu LAN Adapter RJ45 10/100 Mbit Netzwerk Ethernet
There is no brand written on it but it never gave me a problem. I
don't know where you are but I have bought it in the Ebay Germany:
http://cgi.ebay.de/USB-LAN-Adapter-RJ45-10-100-Mbit-Netzwerk-Ethernet-/320482282581?cmd=ViewItem&pt=DE_Computer_Peripherie_Netzwerk&hash=item4a9e3b8c55
All of them should work out of box. But you might have to enable the
driver in the kernel.
I have an unnamed one with DaviCOM chip
http://cgi.ebay.in/USB-Ethernet-10-100-RJ45-LAN-Network-Adapter-/170508837812?cmd=ViewItem&pt=LH_DefaultDomain_203&hash=item27b31e63b4#ht_926wt_1130
Best Regards,
-Deepak
I use a belkin make and it worked fine.
Cheers,
Neil
I'm using the Apple USB Ethernet adapter (http://store.apple.com/us/
product/MB442Z/A) and it works fine with asix kernel module.
Cheers
Pietro
I use an EMINENT EM1010 without problem.
It's only 10 euro. :wink:
DLink DUB-E100
Checkout http://www.qbik.ch/usb/devices/ this provides an overview of
USB devices used in Linux. It will tell you what does work and which
doesn't.
After fitting the extra capacitor to the C3 board I used to have frequent dropouts of the AMDtek, Inc. AN8515 USB ethernet. I had a Wifi dongle also connected to the 7-port hub then, since giving that away the ethernet dropouts have ceased.
Regards
Sid.
