usb to ethernet interface problem
I am working with beagle board and angstrom distribution.
i have connected ethernet cable though dm9601 usb to ethernet
connector.
i have enable the driver for dm9601 in kernel.
but i cant get ip.
if i give the command "ifconfig eth0" i got the below error
ifconfig: eth0: error fetching interface information: Device not found
or
ifconfig: SIOCSIFADDR: No such device
could please help me regarding on that?
With Regards,
Thangaraj.P
See if it gets enumerated "lsusb", also check "dmesg|less" for errors.
root@beagleboard:~# dmesg|grep eth
[112866.721313] pegasus 1-2.2:1.0: eth0, ADMtek ADM8515 "Pegasus II"
USB-2.0 Ethernet, 00:60:70:01:3e:43
Regards
Sid.
I had the same problem before my bb burned (for a completely different reason of course!). USB device was detected as far as dmesg shows, but, I couldn’t see any device except ‘lo’ when I do ‘ifconfig -a’. I couldn’t see any obvious errors in the log.
Sid,
There was no ‘lsusb’ in the busybox that I compiled. Where did you get it from?
–Krishna/.
hi ,
there was no lsusb command.
where we have to enable in the distribution?
I couldn't see any device except 'lo' when I do 'ifconfig -a'. I
couldn't see any obvious errors in the log.
Sid,
There was no 'lsusb' in the busybox that I compiled. Where did you get
it from?
--Krishna/.
OK, sorry it's in "unstable", "cat /proc/bus/usb/devices" gives the same
info.
Regards
Sid.
hi ,
It's in koen's unstable branch, sorry - "cat /proc/bus/usb/devices" in
the standard distribution.
Regards
Sid.
