I’ve got a BeagleBone running 3.2.16, hoping to get a system running that supports both wifi and PWM capabilities. I’ve got a rt2800usb adapter and a Belkin that seems happy with the zd1211rw drivers. Both prompt a wlan0 entry to show up in iwconfig’s output when they’re plugged in.
0: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
rfkill unblock 0 or rfkill unblock all both seem to return fine. But the state displayed by rfkill list remains the same. And the same error is returned by wpa_supplicant and ifup (well, the latter only if I do an ifdown first – otherwise it returns an error about the device already being configured).
Other miscellaneous notes: I’ve done a full opkg upgrade. I’ve tried both enabling and disabling WiFi in /var/lib/connman/settings (it’s normally disabled), which changes the error message to one about wlan0 being a file/device that’s not found. I’m guessing it’s best to leave it disabled and keep connman out of all of this.
Any ideas? Help would be greatly appreciated – I’ve been wrestling to get both wifi and PWM working simultaneously off and on for months now.
Hello Tom!
I have the same problem … To make it work I put the image of Ubtuntu Need. I do not know what happens, I believe to be some setting in the image Ansgtrom, but nobody can tell me what it is.
Thanks, Nilson! I would hate to have to abandon Angstrom after spending so much time working on it, but perhaps I’ll have to. Do you know if PWM and GPIO work properly on the BeagleBone with Ubuntu?
Hello Koen!
I installed the latest version of the image Angstrom. I had the wlan0 recognized, but not connected with the settings I made. Do you have any recommendation to make to set the image Angstrom? I would prefer to work with the Angstrom image …
Hello Koen!
I installed the latest version of the image Angstrom. I had the wlan0 recognized, but not connected with the settings I made. Do you have any recommendation to make to set the image Angstrom? I would prefer to work with the Angstrom image ...
As did I, with the USB WiFI device purchased from AdaFruit. No dice. Just to be clear, this is with [Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.05-beaglebone-2012.05.09.img.xz](http://downloads.angstrom-distribution.org/demo/beaglebone/Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.05-beaglebone-2012.05.09.img.xz)
