Hi all,
I’ve installed version 13.04 (timestamp 2013-05-29).
Configured the whole the system, gave it a static IP, etc.
I want to use the BBB as a rsync backup server.
I’m testing the USB drive (3TB, USB3) right now and running into a small issue.
I created a partition and filesystem (ext4) on the disk. In fstab I added this line:
/dev/sda1 /mnt/data ext4 defaults,noatime 0 0
When mounted is says:
/dev/sda1 2884024544 74736 2737443056 1% /mnt/data
So all looks good.
But when the drive is mounted, it refuses to spin down. Which ever tool I use (hdparm, sdparm and even hd-idle), all don’t work.
It looks like when the drive is mounted it has a hold on the drive and will not let go.
As soon as the drive is unmounted again it spin down almost instantly.
Is there a way to spin down the drive even if it is mounted?
For now I can adjust my script to unmount drive after backup and mount it when starting the backup, but I rather not.
Any help would be welcome!
Further investigation:
For testing I’ve changed the spindown idle time to 5 seconds.
hdparm -S 1 /dev/sda1
/dev/sda1:
setting standby to 1 (5 seconds)
And yes, the drive spins down. But unfortunately it starts to spin up right after the spindown. And 5 seconds later it does the same thing all over again.
Setting the spindown idle time back to 15 minutes:
hdparm -S 180 /dev/sda1
/dev/sda1:
setting standby to 180 (15 minutes)
And the drive keeps spinning.
lsof says that there are no processes running on the mountpoint (/mnt/data) or the disk (/dev/sda1).
I also followed these steps to ensure that nothing is running, that could access the drive.
http://info4admins.com/tips-to-spindown-your-hard-disk-in-debian-or-ubuntu/
I’m getting more and more the idea that there is some kernel process interfering or running a heartbeat on the mountpoint, because the access led on the USB HDD case is blinking every 5 seconds.
Is anybody else experiencing the same issue?
Any help is welcome!
Thx.
