I just grabbed the 2015-12-07 image and flasher image and placed them on separate uSD cards. I used the flasher image to flash the eMMC. Board boots fine.
I then inserted the uSD card with the normal image. Apparently, it doesn’t automagically mount anymore. I see in ``dmesg that the system sees the new device:
[ 598.137586] mmc0: new high speed SDHC card at address aaaa
[ 598.150733] mmcblk1: mmc0:aaaa SE32G 29.7 GiB
[ 598.161203] mmcblk1: p1
lsblk
can see the uSD card:
debian@beaglebone:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0boot0 179:8 0 2M 1 disk
mmcblk0boot1 179:16 0 2M 1 disk
mmcblk0 179:0 0 3.6G 0 disk
└─mmcblk0p1 179:1 0 3.6G 0 part /
mmcblk1 179:24 0 29.7G 0 disk
└─mmcblk1p1 179:25 0 29.7G 0 part
But, no mountie…
debian@beaglebone:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 0 10M 0% /dev
tmpfs 98M 8.4M 90M 9% /run
/dev/mmcblk0p1 3.5G 2.8G 595M 83% /
tmpfs 245M 4.0K 245M 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 245M 0 245M 0% /sys/fs/cgroup
tmpfs 49M 0 49M 0% /run/user/1000
Note that I can mount the uSD by hand thusly:
debian@beaglebone:~$ sudo mount /dev/mmcblk1p1 temp
/dev/mmcblk1p1 30G 2.7G 25G 10% /home/debian/temp
debian@beaglebone:~$ ls temp
bbb-uEnv.txt dev ID.txt media opt run sys var
bin etc lib mnt proc sbin tmp
boot home lost+found nfs-uEnv.txt root srv usr
I can repeat this same sequence by rebooting from the uSD card and the same happens w.r.t. eMMC.
On another system, (BeagleBoard.org Debian Image 2015-11-01, 4.1.13-ti-r35), I am apparently getting the same behavior.
I seem to remember that automagical mounting of the uSD/eMMC used to happen. Maybe this was explicitly removed to avoid confusion? Or is this something that bit-rotted?
ba
