use debug serial port in Beagle Xm
Hi
Am using Angstrom linux on my Beagle Xm rev C board. I have developed
a application which continuously receives data on the serial port. For
now i have used a usb to serial converter and am receiving data every
second on the serial port. But i want to reduce the burden of
additional serial to usb cable. so is there any way to disable the
console debug port on which boot messages are sent and use that port
in my application.
Thanks in advance
Try removing the console field on the kernel arguments that you pass
to the system through the bootloader environment.
Hi
I have already tried removing the console field on the kernel
arguments but the boot messages do not stop. Is it that i have to
disable it in u-boot and kernel code and then recompile and generate
new u-boot and kernel.
Anuj
Hi
Please Can anyone give me some direction to how to go about disabling
the Boot messages and using the internal serial port in my
application.
Thanks in Advance
Anuj
Hi
Have you found a solution for that cause I want to do the same
Eli
