I have Debian Jessie installed on a BBB Rev C (Linux beaglebone 3.14.26-ti-r39 #1 SMP PREEMPT Mon Dec 8 01:52:29 UTC 2014 armv7l GNU/Linux)
And I have a USB sound card attached to a powered USB hub:
lsusb:
Bus 001 Device 003: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: Black [TI BeagleBone Black], device 0: HDMI hdmi-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Set [C-Media USB Headphone Set], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Unfortunately, any attempt to direct audio output to the card freezes the BBB with no message to syslog. User LED’s 0 and 2 are constant on and LED’s 1 and 3 are constant off.
For example:
speaker-test -Ddefault:Set -c6 -twav
speaker-test 1.0.28
Playback device is default:Set
Stream parameters are 48000Hz, S16_LE, 6 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 2048 to 16384
Period size range from 1024 to 1024
Using max buffer size 16384
Periods = 4
was set period_size = 1024
was set buffer_size = 16384
0 - Front Left
Would anyone have an idea how to approach this?
Thanks.
