Okay, with great thanks to Robert for all his help getting my DTB up-and-running, I've now run into a new issue with GPIO and/or ADC access. It seems that if I do it too rapidly, one of the operations never returns.
I sit in a loop in the main thread, polling two ADC channels, and at the start of the loop, and every 5 times through, I poll a GPIO and set a GPIO. At the end of the loop, I sleep for 100 ms.
This has worked very well under 3.8. Over the last few hours I upgraded to 3.14.26-ti-r43 (with CONFIG_USB_TI_CPPI41_DMA disabled and CONFIG_MUSB_PIO_ONLY enabled). I then customized the dtb with this: http://pastebin.com/ksUU07u0
With all that, my GPIOs and ADC seemed to work fine. But then I removed some logging statements from the main loop, and now the behavior seems to be that the main thread loop hangs on some operation (I use sysfs to access the GPIOs and ADCs). The secondary thread, which is decoding MP3s and playing audio, continues to function. If I hit Control-C, that thread stops, but the process doesn't exit. I can't kill the process at all, and I have to reboot the BBB.
I inserted a 100 ms delay before each of my sysfs operations, and it seems to function correctly.
Note that at first I thought it might be a thread synchronization issue between my two threads (the second thread can be paused by the main via a binary semaphore implemented with C++11 mutex and condition variable). But that code only gets executed if the state of one of the GPIOs changes, and that's not happening.
I also commented out all the GPIO-access code and only polled the ADCs, one after the other, with a 100 ms pause after, and that, too locks up.
I tried to attach to the process with GDB, but I can't seem to interrupt it to see the state of things (similar to how I can't Control-C the process itself).
Any ideas? I can probably live with the pre-call delay, but that seems lame.
Thanks!
