Can I use 16GB SDHC card in Beagleboard directly?
I’ve used SDHC card and it worked.
Hi Saravanan,
i just want to check with you. i am currently using a 4gb SDHC card in my beagleboard revC and am trying to capture GPS data via minicom serial. when i save the data into the SD card…there are missing data as to what i see on the actual minicom screen…do i have to reduce the baud rate(im using 115200) to ensure i log all data received every second or what i can do to ensure there is no data loss?
Hope to hear from you .
Ram
