HI friends, im a newbie, still don’t get my beagle bones black boards from digikey.
For a project i will ned 4 serial ports, i already see i must forget to use HDMI if choice that option. I need also to show on a display data and also allow me interact in a easy way with my program.
Is possible , somebody already try, connect a usb to via adapter and use this as main display? What changes are needed to disable cdmi and set this as main display? Any via adapter tested?
Robert,
Is a perfect solution. Thank you!
Im just trying to understand if usb port is accesible on the GPIO port and allow me, in some way, to design a cape for internal use. My idea is avoid a external usb cable, just lug the beagle bone on the sister board and connect beagle bone usb to serial ports usb , no external wire. Is that possible?
Robert,
Is posible to get on P8 or P9 usb signals? I plan to integrate the CP2108 on a cape board, will not use the SUDB connector, but can’t find the USB signals on this connectors.
