Using an HD TV as a monitor
I just got my BeagleBoard yesterday. When testing it out, I was able
to get a screen displayed on my HD TV through a regular HDMI cable.
Then it took me a day to get Linux installed (I finally chose Ubuntu
Maverick 10.10).
Now I cannot get the HD TV to work as a monitor. The HD TV says
"Signal not supported."
Any suggestions on what to try?
Thank you.
Maverick 10.10).
I guess that ubuntu is using a default dvi resolution that your
TV does not support.
By default that image is using a resolution of "1280x720MR-16@60"
The basicly boot.scr can be created by:
http://elinux.org/BeagleBoardUbuntu#Beagle_xM
and just adjust the resolution parameter to what you need for the tv..
http://elinux.org/BeagleBoardFAQ#.22DSS2.22_display_driver_for_.3E.3D_2.6.29
I tried changing the command.scr file. But when the BeagleBoard booted
I still got the same result:
[ 2.634490] fbcvt: 1280x720@60: CVT Name - .921M9-R
I'm not sure if I'm following the right procedure.
