I tried enabling MMC support in Android kernel menuconfig as shown below for camera application
SCSI Device Support → Proble all LUNS on each SCSI device
USB Support → USB Mass Storage Support
and more n’t exactly sure. For your reference i have attached my .config as ConfigMMC
after enabling i’m able to see MMC Card being detected which is connected to beagle board via USB Card Reader.
The kernel messges is see is listed below
scsi 0:0:0:0: Direct-Access Generic- Compact Flash 1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: [sda] Attached SCSI removable disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
scsi 0:0:0:1: Direct-Access Generic- SM/xD-Picture 1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:1: [sdb] Attached SCSI removable disk
sd 0:0:0:1: Attached scsi generic sg1 type 0
scsi 0:0:0:2: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:2: [sdc] 7959552 512-byte hardware sectors: (4.07 GB/3.79 GiB)
sd 0:0:0:2: [sdc] Write Protect is off
sd 0:0:0:2: [sdc] Assuming drive cache: write through
sdc: sdc1 sdc2
sd 0:0:0:2: [sdc] Attached SCSI removable disk
sd 0:0:0:2: Attached scsi generic sg2 type 0
scsi 0:0:0:3: Direct-Access Generic- MS/MS-Pro 1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:3: [sdd] Attached SCSI removable disk
sd 0:0:0:3: Attached scsi generic sg3 type 0
mount -o rw -t ext3 /dev/block/sdc2 la1
kjournald starting. Commit interval 5 seconds
EXT3 FS on sdc2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
mount -o rw -t msdos /dev/block/sdc1 sdcard
usb 1-1.4: USB disconnect, address 5
after this i tried mounting this sd card “mount -o rw -t ext3 /dev/block/sdc2 sdcard/”, it mounted properly and i’m able to see all contents inside folder named “sdcard”. But the Android application is still asking me to connect sdcard when i try running camera application. This SD card is not even visible in Android settings too. Pls guide me to make camera app running properly on BeagleBoard.
Suresh Kalidasan.
ConfigMMC (36.4 KB)
