I am not able to find the steps for connecting an USB internet(Tata
Photon).
Could i know the genralized steps for connecting internet.
Which OS? On BB or on host PC?
Gopal, Its on BB having angstrom linux on it.
Are you able get your device as /dev/ttyUSBx?? Means if your device is
being recognised ?
no its not recognized
Then you need compile your kernel with the support for your tata photon
driver.. Most probably, it requires option.ko module..
Otherwise to make sure which module is required you first plug your
photon in ur pc and see what are the modules loaded for photon..
then you can select them before compiling your kernel...
Try to do this much then we'll try to connect to internet..
