using jtag emulator xds 510 parallel plus with beagleboard
Previously I implemented dsplink on beagleboard with cross compilers
environment set in linux host. But now i want to do the same using
code composer studio and jtag emulator xds 510. I have both things,
Can anyone please recommend some useful link and summarized the steps
i should follow. your help is highhly anticipated.
Adonis
Hi Adonis,
First of all, you need low voltage JTAG adapter like this (this one is
very expensive, so I guess better option for you is to make your own
voltage translator - chip costs a couple of dollars):
http://www.spectrumdigital.com/product_info.php?cPath=33&products_id=32&osCsid=a5b3bc52a1e1b4db09114fb36066ab90
Which version of TI CCS are you using?
Cheers,
Max.
