I have installed Ubuntu on my Beagleboard (3.0.6 kernel), and it uses my
K3772 USB GSM modem without any problem. I would like to use it on
Angstrom, but have kernel config problems. (3.0.14)
I enabled the following modules: option, usb_wwan, usbserial, cdc_acm,
qcserial, cdc_ether. I found that Ubuntu uses these modules if i connect
the modem.
On Ubuntu, it creates ttyUSB0, ttyUSB1, ttyUSB2, ttyACM0, ttyACM1
devices, but on Angstrom no such devices, even if all modules are
loaded.
The kernel log messages:
usb 1-2.3: new high speed USB device number 15 using ehci-omap
usb 1-2.3: New USB device found, idVendor=19d2, idProduct=1179
usb 1-2.3: New USB device strings: Mfr=2, Product=1, SerialNumber=3
usb 1-2.3: Product: K3772-Z
usb 1-2.3: Manufacturer: Vodafone
usb 1-2.3: SerialNumber: 1296BFEFEA4FA1C362D155E0D6CB284DC6F70C79
scsi4 : usb-storage 1-2.3:1.0
scsi 4:0:0:0: CD-ROM Vodafone USB SCSI CD-ROM 0001 PQ: 0
ANSI: 0
sr0: scsi3-mmc drive: 0x/0x caddy
sr 4:0:0:0: Attached scsi generic sg1 type 5
sr0: CDROM (ioctl) error, command: cdb[0]=0x4a 4a 01 00 00 10 00 00 00
08 00
sr: Sense Key : 0x4 [current]
sr: ASC=0x0 ASCQ=0x0
sr0: CDROM (ioctl) error, command: cdb[0]=0x51 51 00 00 00 00 00 00 00
02 00
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
Something similar is common for both systems.
The following happens on Ubuntu: (the Angstrom does not print any more)
cdc_acm 1-2.1:1.1: ttyACM0: USB ACM device
cdc_acm 1-2.1:1.3: ttyACM1: USB ACM device
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN
adapters
scsi 2:0:0:0: CD-ROM Vodafone USB SCSI CD-ROM 0001 PQ: 0
ANSI: 0
sr 2:0:0:0: Attached scsi CD-ROM sr0
sr 2:0:0:0: Attached scsi generic sg1 type 5
sr0: CDROM (ioctl) error, command: Xpwrite, Read disk info 51 00 00 00
00 00 00 00 02 00
sr: Sense Key : Hardware Error [current]$
sr: Add. Sense: No additional sense information
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
usb1: no IPv6 routers present
option 1-2.1:1.0: GSM modem (1-port) converter detected
usb 1-2.1: GSM modem (1-port) converter now attached to ttyUSB0
option 1-2.1:1.8: GSM modem (1-port) converter detected
usb 1-2.1: GSM modem (1-port) converter now attached to ttyUSB1
Something can be missing from my Angstrom config, but i don't know what.
Thanx in advance
Gyorgy Kovesdi
