using multiple analog inputs
I have searched BeagleBoard forums for this answer but only found single A/D responses. Since I already have a single A/D channel working this was no help.
I am trying to read two analog pins but I get the following error message:
var r = binding.read(fd, buffer, offset, length, position);
Error: EAGAIN, resource temporarily unavailable
at Object.fs.readSync (fs.js:481:19)
at Object.fs.readFileSync (fs.js:315:28)
at Object.exports.readAIN (/usr/local/lib/node_modules/bonescript/hw_capemgr.js:214:30)
at Object.f.analogRead (/usr/local/lib/node_modules/bonescript/index.js:229:15)
The code below is from the ‘fade’ demo example. I can read either one at a time but when both are in the loop the error occurs after a while. Is the ADC still busy when the second analogRead occurs?
Linux beaglebone 3.8.13-bone47 #1 SMP Fri Apr 11 01:36:09 UTC 2014 armv7l GNU/Linux
BeagleBone Black rev 00C0 running BoneScript 0.2.4
var b = require(‘bonescript’);
// setup starting conditions
var awValue = 0.01;
var awDirection = 1;
var awPin = “P9_14”;
var AnaloginputPin = “P9_38”;
var MyTargetVoltage = 0;
var PWMAnalogVoltage = “P9_36”;
var PWMAnalogVoltVal = 0;
var Analogvalue = 0;
// configure pin
b.pinMode(awPin, b.ANALOG_OUTPUT);
// call function to update brightness every 10ms
setInterval(fade, 100);
// function to update brightness
function fade() {
b.analogWrite(awPin, awValue);
awValue = awValue + (awDirection*0.01);
Analogvalue = b.analogRead(AnaloginputPin);
MyTargetVoltage = Analogvalue * 1.803;
console.log(MyTargetVoltage);
PWMAnalogVoltVal = b.analogRead(PWMAnalogVoltage) * 1.803;
console.log(PWMAnalogVoltVal);
if(awValue > 1.0) { awValue = 1.0; awDirection = -1; }
else if(awValue <= 0.01) { awValue = 0.01; awDirection = 1;
output is
0.20333833333333334
0.44273666666666667
0.18530833333333332
0.44273666666666667
0.19632666666666665
0.441735
0.18130166666666664
0.44273666666666667
0.23338833333333334
0.441735
0.22136833333333333
0.44273666666666667
0.19332166666666664 … until error message
i am not sure but i think buried somewhere in the BBB service reference manual ( i think that is the right name ) it mentions something that made me think, there is only one A/D converter and the other inputs are multiplexed. Another thing to check might be the pin you are trying to use maybe already used by some other device or service. I am using an LCD 7 which consumes four of the A/D inputs.
hope that helps !
I can not speak to bonescript, or what you’re using javascript wise. But I can say that this error can happen when the ADC channel in question is not done updating the “buffer”.
So in the C programming language, what you end up having to do is close the file descriptor, reopen the file descriptor, then try again. When the length of the read file descriptor returns -1. How this applies to your javascript code . . . I could not say, but there you have it.
Ok, so, this line of code: Analogvalue = b.analogRead(AnaloginputPin);
You need to:
  1. Check the value of Analogvalue
  2. If the value is -1, then reread the value until the value is greater than 0( zero means buffer empty )
  3. Once the value is a positive value, then you can process Analogvalue accordingly.
Thanks for all your help. Based on your answers I added a try & catch on the AnalogRead and that traps the error and keeps the code running so I can retry the read. I am a C (with some C++) programmer so if I was doing this in C I would find the A/D busy flag in a register somewhere and only read when not busy. But I am trying to learn something new so I am learning BoneScript - for better or worse. Pretty sure I will be programming in C soon!
Don, check out my recent blog post on ADC’s here. http://www.embeddedhobbyist.com/2015/10/beaglebone-black-adc/
It covers setup for 4.x kernels, and sample code in C. If you need less than ~5800 samples a second for reads. This will work fine for you. If you need faster speeds, I’ll be putting up a post on running continuous mode using the TI userspace driver. Sometime after that, mmap() + /dev/mem, and then using the PRU’s to do the same task, but to offload the main processor.
So also, if you want to output data to a web browser. You can use bare Nodejs. It would also probably be necessary to use /dev/shm ( POSIX shared memory ), and a C app to write the data out of the ADC into that file. Nodejs + fileWatcher() could be used to shuffle that data over a websocket. I’ve done something similar, but using all C + libmongoose. libmongoose to handle the web / websocket duties. All C has the advantage of being at least 4-5x faster. Which libmongoose is a C library for those duties, and more.
