Using nano on Eclipse with Remote System Explorer's ssh terminals
Can anyone offer any hints about using the nano editor via the Remote System Explorer’s ssh terminal? I can’t seem to navigate around the editing screen, and end up starting PuTTY to edit files. Are their some configuration files that have to be set up on Eclipse or the RSE?
http://www.codexpedia.com/text-editor/nano-text-editor-command-cheatsheet/
Thanks for the link Robert. My problem isn’t with nano, but with figuring out how to make it work (if possible) when run through the RSE interface of Eclipse. As it is, I do my BBB file editing with nano via PuTTY – but would really like to be able to do everything from the Eclipse platform if I can.
To anyone that may stumble on this later – run “screen” before nano and you’ll find it behaving as you would expect on an Eclipse RSE ssh terminal.
