Using WiLink 8 software on BeagleBone Green Wireless
Hi!
I installed TI SDK + WiLink 8 Software on BBGW using attached PDF file instruction.
I had few question about so far I did on BBGWs
I had major issue with packet forwarding between interfaces
First, I would like to explain how did I set up the network
I would like to extend AP(Phantom_ 6132f6) which is came from DJI drone network
The current DJI drone network is
Drone(Camera hidden SSID : FC200_0176db) <-> Range extender(AP : Phantom_6132f6) <-> User Phone(DJI APP)
What am I going to do is
Drone(Camera hidden SSID : FC200_0176db) <-> Range extender(AP : Phantom_6132f6) <-> [wlan0(STA)-BBGW(1)-mesh0(MESH)]
[mesh0(MESH)-BBGW(2)-wlan0(AP : Phantom_GS)]<-> User Phone(DJI APP).
Here is what I did so far
BBGW(1) status
run the script
/usr/share/wl18xx/sta_start.sh
#!/bin/sh
if ps -w | grep -v grep | grep wpa_supplicant | grep wlan0 > /dev/null
then
echo “wpa_supplicant is already running”
exit 0
fi
if [ ! -f /usr/share/wl18xx/wpa_supplicant.conf ]
then
if [ ! -f /etc/wpa_supplicant.conf ]
then
echo “error - no default wpa_supplicant.conf”
exit 1
fi
cp /etc/wpa_supplicant.conf /usr/share/wl18xx/wpa_supplicant.conf
fi
wpa_supplicant -e/usr/share/wl18xx/entropy.bin
-iwlan0 -Dnl80211 -c/usr/share/wl18xx/wpa_supplicant.conf &
/usr/share/wl18xx/sta-connect_ex.sh Phantom_6132f6
#!/bin/sh
NETID=0
WPA_CLI=‘wpa_cli -i wlan0’
if [ $# -eq 0 ] || [ “$1” == “–help” ] || [ “$1” == “-h” ]; then
echo “”
echo “You must specify at least the network ssid”
echo “format: $0 [key_mgmt] [psk]”
echo “”
echo “supported key-mgmt: NONE, WPA-PSK”
exit
fi
NETID=$WPA_CLI add_network | grep -v Using | grep -v Selected
echo “netid=”$NETID
echo “=========================”
echo $WPA_CLI set_network $NETID ssid ‘""$1""’ > /usr/share/wl18xx/temp.txt
if [ $# -gt 1 ]; then
if [ “$2” == “WPA-PSK” ] || [ “$2” == “NONE” ] ; then
echo $WPA_CLI set_network $NETID key_mgmt “$2” >> /usr/share/wl18xx/temp.
else
echo “Sorry, but only WPA-PSK and NONE key_mgmt is supported”
exit
fi
else
echo $WPA_CLI set_network $NETID key_mgmt NONE >> /usr/share/wl18xx/temp.txt
fi
if [ $# -gt 2 ]; then
echo $WPA_CLI set_network $NETID psk ‘""$3""’ >> /usr/share/wl18xx/temp.
fi
echo $WPA_CLI select_network $NETID >> /usr/share/wl18xx/temp.txt
chmod 777 /usr/share/wl18xx/temp.txt
sh /usr/share/wl18xx/temp.txt
rm /usr/share/wl18xx/temp.txt
#udhcpc -i wlan0
./udhcpc -i wlan0
./mesh_start.sh
MESH=mesh0
add Mesh interface, if not present
if [ ! -d /sys/class/net/$MESH ]
then
echo “adding $MESH interface”
iw phy ls /sys/class/ieee80211/ interface add $MESH type mp
fi
if ps -w | grep -v grep | grep wpa_supplicant | grep mesh0 > /dev/null
then
echo “wpa_supplicant is already running(Mesh)”
exit 0
fi
-imesh0 -Dnl80211 -c mesh_supplicant.conf &
sleep 1
iw phy phy0 set rts 0
ifconfig mesh0 192.168.2.2 netmask 255.255.255.0
Result
ifconfig
본문 이미지 1
route
본문 이미지 2
iptables
본문 이미지 3
BBGW(2) status
run the script
/usr/share/wl18xx/ap_start.sh
#!/bin/sh
########## variables ##########
WLAN=wlan0
WLAN2=wlan2
HOSTAPD_PROC=/var/run/hostapd
HOSTAPD_CONF=/usr/share/wl18xx/hostapd.conf
HOSTAPD_BIN_DIR=/usr/sbin
IP_ADDR=192.168.1.100
IP_ADDR2=192.168.53.1
DHCP_CONF=udhcpd.conf
DHCP_CONF2=udhcpd2.conf
DHCP_CONF_PROC=u[d]hcpd.conf
DHCP_CONF_PROC2=u[d]hcpd2.conf
########## body ##########
check for configuration file
if [ ! -f $HOSTAPD_CONF ]; then
if [ ! -f /etc/hostapd.conf ]
then
echo “error - no default hostapd.conf file”
exit 1
fi
cp /etc/hostapd.conf $HOSTAPD_CONF
chmod 777 $HOSTAPD_CONF
fi
configure ip forewarding
echo 1 > /proc/sys/net/ipv4/ip_forward
add WLAN interface, if not present
if [ ! -d /sys/class/net/$WLAN ]
then
echo “adding $WLAN interface”
iw phy ls /sys/class/ieee80211/ interface add $WLAN type managed
fi
start a hostapd interface, if not present
if [ ! -r $HOSTAPD_PROC ]
then
$HOSTAPD_BIN_DIR/hostapd $HOSTAPD_CONF &
sleep 1
fi
configure ip
ifconfig $WLAN $IP_ADDR netmask 255.255.255.0 up
if [ -d /sys/class/net/$WLAN2 ]
then
ifconfig $WLAN2 $IP_ADDR2 netmask 255.255.255.0 up
fi
start udhcpd server, if not started
output=ps | grep /usr/share/wl18xx\$DHCP_CONF_PROC
set – $output
echo $output
if [ -z “$output” ]; then
udhcpd $DHCP_CONF
fi
then
output=ps | grep /usr/share/wl18xx\$DHCP_CONF_PROC2
set – $output
echo $output
udhcpd $DHCP_CONF2
fi
fi
configure nat
#iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
./mesh_start.sh
MESH=mesh0
then
fi
then
exit 0
fi
sleep 1
ifconfig mesh0 192.168.2.1 netmask 255.255.255.0
Result
ifconfig
본문 이미지 4
route
본문 이미지 5
iptables
본문 이미지 6
For the /etc/sysctl.conf on both BBGW
본문 이미지 7
본문 이미지 8
본문 이미지 9
So When I connect to User Phone on BBGW(2) AP : Phantom_GS. It does not show the live stream data
Could you help with building network? I can not figure out what is the problem and where should I fix it
It seems like I have to dealing with IP forwarding and configure firewall(iptables?)
Only thing I can verified that mesh network is working nothing else
Thank you
TI Wilink 8 Linux SDK.pdf (641 KB)
