I patched a vanilla kernel for realtime and configured it for omap3 beagle. However, after building it using make-kpkg with “DEB_HOST_ARCH=armhf CLEAN_SOURCE=no fakeroot make-kpkg --arch=arm --subarch=omap3 --cross-compile=arm-linux-gnueabihf- --initrd --append-to-version -xenomai-2.6.3-omap3 --revision 1.4 kernel_image kernel_headers”, synaptic tells me it’s armhf but no omap kernel. Despite searching, how should I patch this vanilla kernel for omap3 so it runs on the BBxM ?
Oh, I did. Have reconfigured, rebuilt and tested 4 times by now, and keep getting the dpkg message that it’s not an omap kernel.
I took vanilla kernel 3.5.7 because of a necessary patch that supports this version. Is there any other kernel version you can recommend for omap3 ?
"DEB_HOST_ARCH=armhf CLEAN_SOURCE=no fakeroot make-kpkg --arch=arm
kernel_headers", synaptic tells me it's armhf but no omap kernel. Despite
the BBxM ?
Don't use the "subarch" flag with make-kpkg, it's for something else,
not related to the "soc" family of arm devices..
So I should use this exact build string, but without --subarch and
will get an armhf kernel with omap3 ?
The answer to the first part should have been implied from my last
email..
The second part, totally depends on what features you enabled for the
"omap3" devices in your kernel .config.
I configured it generally for omap2+, omap3 and beagle. Should there be
more features to enable to have it run on BBxM with Ubuntu Precise ?
More then likely yes.. But it depends on the kernel version.. So go
build/test/enable/rebuild/test/etc...
getting the dpkg message that it's not an omap kernel.
removing the "--subarch" crap will fix that...
I have removed the “subarch” flag, and now I get the error message “Kernel <…> does not match your subarchitecture omap, therefore not writing it to flash.”. The running kernel (Ubuntu 12.04 omap armv7l) is v3.2.0-55-omap from repo. I noticed that the latest stable kernel indeed has a different configuration for omap. But I wonder, where does that message about “subarchitecture omap” really come from? The kernel configuration or the cross-compilation?
the BBxM ?
Don't use the "subarch" flag with make-kpkg, it's for something else, not
I have removed the "subarch" flag, and now I get the error message "Kernel
<.....> does not match your subarchitecture omap, therefore not writing it
to flash.".
Okay.. "not writing it to flash" your dealing with ubuntu's flash-kernel
script. So when you install a *.deb, dpkg calls "flash-kernel"...
It's a middle layer script that ubuntu wrote to "generically" install the
boot files to the correct location for a bunch of devices. Unless you run
ubuntu's kernel, it just gets in the way..
I disable flash-kernel outright, as it always makes the wrong assumptions.
via:
"subarchitecture omap" really come from? The kernel configuration or the
cross-compilation?
So good luck with dealing with the flash-kernel script..
