I am working on mplayer, I am facing an issue of video quality.
When I run a video on native system there is no blocking effect
observed(no blocks are visible), but when I cross compile same mplayer
code for ARM (beagle board) when i run the same video I observed lot
of blocks in the video.
If anybody is having any idea on this please let me know what will be
the cause of the problem?
I seem to remember something similar that was due to the version of gcc. Google the list for gcc and mplayer. The issue was that the version of gcc was also unable to compile a kernel. Does that gcc compile the kernel successfully? Both kernel compilation and optimized code for media codecs tend to uncover compiler bugs from what I’ve read. Try the same gcc used to compile the kernel.
FYI:Linux2.6.22.18 kernel
That was actually a bug in FFmpeg/mplayer which has long since been
fixed.
for media codecs tend to uncover compiler bugs from what I've read.
The recommended compiler for FFmpeg and MPlayer is codesourcery gcc
2007q3.
Hi
I took the dump of the video frames before sending the frames to the
display driver(vo driver) on target and native system.
I compared bit by bit of each frames, they are same.
I am using gcc compiler of 2008q1 version.
I will give a try with 2007q3 compiler.
Thanks for your help.
