Video output to S-Video
Hi everyone,
Is it possible to get the video output directed to S-Video instead of
DVI-D... I am running the Angstrom Demo image.
Regards
-Nitin
If you use the 2.8.28rcX uImages that were posted to this list earlier you can get s-video support.
regards,
Koen
Thanks a lot…
-Nitin
Thanks a lot...
For havinf different outputs on dvi and s-video you could use this
script to enable s-video (from Tomba, the father of DSS2):
tvline=`cat /sys/devices/platform/omapfb/displays |grep tv`
w=`echo $tvline | cut -d " " -f 2 | cut -d ":" -f 2`
h=`echo $tvline | cut -d " " -f 3 | cut -d ":" -f 2`
echo "vid1 t:none" > /sys/devices/platform/omapfb/overlays
fbset -fb /dev/fb1 -xres $w -vxres $w -yres $h -vyres $h
echo "vid1 t:tv w:$w h:$h e:1" > /sys/devices/platform/omapfb/overlays
echo "tv e:1" > /sys/devices/platform/omapfb/displays
What it does is:
Hi,Robert
How did you make the uImage with the S-video patch?
which linux kernel did you use?
I git the kernel from
http://www.bat.org/~tomba/git/linux-omap-dss.git/
and compiled it to the uImage, but when i boot it, i cant see "omapfb"
exist in /sys/devices/platform/.
so i thought i should add patch into the DSS kernel, but the version
seems not right, i got some patch and compling errors.
am i right?
And, i have a question : the patch seems only support OMAP3430 instead
of OMAP 3530 which Beagleboard is using.
Thanks.
Liahoo
What kernle config do you use? You has to enable DSS2 in the kernel
config. Its under driver->graphics (or something like that).
The kernel from the above side has all necessary. It is from the
creater of DSS2.
HTH.
Robert
Hi Robert!
Thanks for your help!
i got the config file and succeeded to build the uImage.
after this, i made a change for Android RootFS.
just patch Android support into the kernel(DSS) from this site:
http://sites.google.com/site/voyageofbeagleboard/how-to-make-kernel
and , i merged you configfile to the "omap3_beagle_android_defconfig"
which is created by the patch.
it was compiled all right, and i could start the android by typing the
"ls" command.
But when i typed the command , i couldn't see the S-Video output
anything.
my steps are:
1, git the kernel from
2, merge kernel config to omap3_beagle_defconfig.
3, get android patch from
4, patch the file to kernel
5, merge omap3_beagle_defconfig to omap3_beagle_android_defconfig.
6, make the image with omap3_beagle_android_defconfig.
7, use the uImage and boot with Android rootFS which i made before
like this site:
http://labs.embinux.org/android-porting-on-beagle.html
8, connect beagleboard S-Video...
9, boot Android.
10,when i typed the commands like "echo "vid1 t:none" > overlays ", i
got nothing output in S-Video.
Any ideas?
Best Regards!
Hu Liang.
anything.
my steps are:
What does
  grep DSS .config
or
  grep DSS omap3_beagle_defconfig
outputs?
The relevant setting is CONFIG_OMAP2_DSS
Robert
What does
  grep DSS .config
or
outputs?
Sorry,i cant use the S-Video device right now. but in command line, it
appears:
# tvline=`cat /sys/devices/platform/omapfb/displays |grep DSS .config`
grep: not found
# tvline=`cat /sys/devices/platform/omapfb/displays | grep
DSS .config`
grep: not found
omap3_beagle_android_defconfig`
grep: not found
grep: not found
omap3_beagle_defconfig`
grep: not found
grep: not found
Actually, i met it at the first time with "tvline=`cat /sys/devices/
platform/omapfb/displays |grep tv`"
But i changed the symbol ` to ' :frowning:
So i think i made a mistake about the ` symbol...
But how about the "grep: not found" issue to fix?
i opened CONFIG_OMAP2_DSS before i compiled the kernel:
CONFIG_OMAP2_DSS=y
# CONFIG_OMAP2_DSS_DEBUG is not set
# CONFIG_OMAP2_DSS_RFBI is not set
CONFIG_OMAP2_DSS_VENC=y
# CONFIG_OMAP2_DSS_SDI is not set
# CONFIG_OMAP2_DSS_DSI is not set
# CONFIG_OMAP2_DSS_FAKE_VSYNC is not set
CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=4
CONFIG_ARCH_OMAP34XX=y
CONFIG_ARCH_OMAP3430=y
by the way ,can you tell me how to upload a file like my configfile?
Best Regards!
Hu Liang
What does
  grep DSS .config
or
outputs?
You are right!
grep command is not supported by Android RootFS , so i got errorlog
like "grep: not found".
Any ideas for adding the commands of Linux to Android RootFS?
Hu Liang wrote:
What does
  grep DSS .config
or
outputs?
You are right!
try grep on your PC, not the android :wink:
Hi Vladimir,
Actually i tried grep in u-boot on my PC connected to Beagleboard with
series line.
When Android is started, i can type simple command as "ls" in android
command environment,
which is the same as the command line by "adb shell" in PC.
i think there is no "grep" in android's commands, so i want to add
some into it.
Best Regards!
Hu Liang.
Hi Robert,
i made the grep and cut command available by putting a busybox into
android rootfs.
and my log is:
# tvline=`cat /sys/devices/platform/omapfb/displays |grep tv`
# w=`echo $tvline | cut -d " " -f 2 | cut -d ":" -f 2`
# h=`echo $tvline | cut -d " " -f 3 | cut -d ":" -f 2`
# echo "1 t:none" > framebuffers
# echo "0 t:gfx,vid1" > framebuffers
# echo "gfx e:1" > overlays
# echo "vid1 t:tv w:$w h:$h e:1" > overlays
omapfb omapfb: enable overlay failed
# echo "tv e:1" > displays
i think the grep command from android's busybox didnt works.
i tried:
# ln -s /system/bin/busybox grep
# ln -s /system/bin/busybox cut
# echo $tvline
