Video playing
What is the best solution to play video ?
I tried the "big bunny" (640x360), was working not too bad with omapfbplay, but was very laggy with mplayer.
Another thing, can 720p video decoding work (I use B4) ? Or do we need to wait for xM ?
Guizmo
Try gstreamer with the TI plugins - they should already be installed
in the Angström demo image IIRC. Those utilize the DSP so it should
give you 720p at a reasonable frame rate.
Yaman
Thank you, I'll try...
add “mem=99M@0x80000000 mem=128M@0x88000000” arguments to the “bootargs” in u-boot.
2010/7/7 Yaman Umuroglu <maltanar@gmail.com>
Did it worked?
Renan
I didn't have the time to try yet, I'll do it tonight.
Le 07/07/2010 14:52, Renan Biegelmeyer a �crit :
With 720p i can’t have reasonable frame rate. Up to 6-8fps, no more.
att,
  • Roberto
it depends on the file format used. Of course, the file created for PC will run very slow on BB.
2010/7/7 Roberto Alcântara <roberto@eletronica.org>
What format will be the best for BB ?
Do you think the xM will be able to handle it ?
Video in h264 and 720p run very slow on the beagleboard.
With omapfbplay, average frame rate is around 7 fps while video in MP4
run around 15 fps.
I measured the performance with big_buck_bunny_720p.
I didn't try with gstreamer but if you get similar results I think you
aren't using the DSP.
Giovanni
Why don’t search through this mail-list? This topic was discussed a lot and especially for xM
2010/7/7 Guillaume Duteil <g.duteil@alsim.com>
